1986 4x4 22re code questions - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 2 Old 01-10-2012, 11:47 PM Thread Starter
wife 86 4x4 me tundra
Quoted: 0 Post(s)
(Thread Starter)
Hey fellas
Diagnostic code question,
I have searched for an answer and found a good way of checking to see what codes i have or not?
in the directions it shows the following:
_____________________________________________
Turn ignition switch to ON position.
  • Do not start the engine.
  • Place a jumper wire across TEl and El terminals in engine check connector.
Count number of flashes from CHECK ENGINE light.
  • If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
    and evenly about 2 times a second.
Otherwise, the light will blink a number of times equal to the trouble code as follows:
  • The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
  • The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
  • If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
  • Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
__________________________________________________ ______
On the wifes truck, it does the following.
light on...light off then 3.5 seconds light on then off then 3.5 seconds simply over and over again.
no difference whatsover, on off on off 3.5 seconds intervals.
is this a normal condition or is it giving me a number to go by??
Being the big goon, my brain is on goon overload, i cannot firure out how to tell.
please help
goon
The BIG Goon is offline
post #2 of 2 Old 01-11-2012, 05:56 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 214 Post(s)
The closest thing to that would be Normal Operation for a 22RTE, which is once every 4.5 sec.
So it does not seem to be a useful result as you've found
No THANKS necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
The Following User Says Thank You to fourwd1 For This Useful Post:
The BIG Goon (01-14-2012)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
