87 22r fuel sending unit - Toyota Nation Forum : Toyota Car and Truck Forums
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux.
post #1 of 8 Old 03-11-2012, 12:15 PM Thread Starter
Matt22r's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hi I'm new here n I picked up an 87 4x4 5spd with 251xxx miles a few months ago. When I got it the gas gauge doesn't really work right. When I fill up it says full but when I drive like 60 or so miles the gauge goes to empty. I think it might be the fuel sending unit but I'm not sure. And if it is I found one from a 92 for $50. Will that one work for my truck?
Sent from my Autoguide iPhone app
Matt22r is offline
post #2 of 8 Old 03-11-2012, 07:22 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 250 Post(s)
You might try pulling your sending unit out and cleaning the windings with some electrical contact cleaner.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #3 of 8 Old 03-13-2012, 04:17 PM
Quoted: 0 Post(s)
I had the same problem with my 87; dropped the gas tank and found that the winding on the sending unit were worn on bottom half. Mine would register until it got to a half tank then go to nothing.
Don't know about the fit from a 92, I would drop the tank and put the old one then you should be able to see if the other one is the same.
Later,
WJMOPAR
wjmopar is offline
post #4 of 8 Old 03-21-2012, 10:13 AM Thread Starter
Matt22r's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hey thanks guys for helpin me out. I'm gonna have to wait till it warms up here to drop the tank n get to it since I'm in Alaska. And it's still pretty cold up here -10.
Matt22r is offline
post #5 of 8 Old 07-02-2015, 08:10 PM
Quoted: 0 Post(s)
this is an old string but i'm curious what the name in the chiltons would be for an 87 22r sending unit. sometimes the books are ridiculous in describing things. got the same issue with the gas gauge all over the place. thanks guys.
Boxil is offline
post #6 of 8 Old 07-03-2015, 04:28 AM
Quoted: 0 Post(s)
I don't have a Chilton for my Toyota; however, I believe it is probably shown on the fuel pump if you have a diagram, etc. for that. I have a Toyota 87 Manual if you have a question maybe the answer would be in that. Let me know.
wjmopar is offline
post #7 of 8 Old 07-03-2015, 11:03 AM
Quoted: 0 Post(s)
i just inherited an 87 and am trying to go through all the little issues. i've got a chiltons and the owners manual. havn't checked the owners manual yet. frustrating not knowing how much fuel you got except for basic math calculations to get you in the ball park.
How easy was it dropping the tank? would you have rather taken the bed off or was the tank easier?
Boxil is offline
post #8 of 8 Old 07-03-2015, 12:52 PM
Quoted: 0 Post(s)
I don't recall any major problem dropping the tank. I ran it down until the light came on and then parked it and let it run out of gas. I was surprised at how long it took to run out, couple of hours idling.
I have removed the bed before and I think it is easier to drop the tank but either one would work.
Have fun....
wjmopar is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
User Tag List
Linear Mode Linear Mode
Back
