There is a headlight dimmer switch located in the steering column. There is a differnet set of contacts for flash (holding the lever back) and high beams. Send me a PM with an email address and I can send you a pic of the pin-out for the connector. Basically, terminals 5,12,13 are shorted on flash and only 5,13 are shorted on high beams. Terminals 6,13 are short for low beams.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
