Gear Ratios - 1988 Pickup - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 12-30-2004, 12:29 PM   #1 (permalink)
View matthogan's Photo Gallery
I own a 1988 Toyota pickup with 23 ER motor. The rear end blew out and I need a ring and pinion set but since I don't want to spend much money I located a 1986 Toyota pickup with the same motor 2 wheel drive for free. What are the chances the gear ratios in the rear are the same?
- Matt Hogan
matthogan is offline   Reply With Quote
Old 10-08-2005, 09:55 AM   #2 (permalink)
View Phat_Phingers's Photo Gallery
check the tire sizes, my 86 2wd is geared pretty slow (numerically high) with 14 in wheels, is yours a 4x4? otherwise VIN # at dealer ship might be able to find out
Ottawa ON
86 Pickup
97 TacoMa
Phat_Phingers is offline   Reply With Quote
Old 10-08-2005, 03:42 PM   #3 (permalink)
DCM
One with the farce
View DCM's Photo Gallery
Check the VIN tag under the hood; it'll tell you all you need to know. Something like "axl/trans" etc. Match up the numbers that fall under the "axle" part of the tag, such as "G292" which means a 8" 4:10 2-pinion open diff or "G254" which indicates a 8" 4.56 4-pinion diff. There's a wide range of gearing, my trucks range from 3.07:1 to 4.88:1.
If your ring and pinion blew, you'd be better off to get a third member instead of just the gears. That way you don't have to pay to have it set up.
DCM is offline   Reply With Quote
Old 10-09-2005, 10:25 AM   #4 (permalink)
View Sidney's Photo Gallery
http://www.sr5.net/sr5axles.htm
http://www.4crawler.com/4x4/ToyVIN.shtml
http://www.showmesome.info/hilux/info/vin/
http://www.4runners.org/articles/vin_code.html
http://www.off-road.com/toyota/tech/other/4_dts.html
http://www.autoinsurancetips.com/toyota_vin.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 245 000 KM
O
|\ __O
_|_| \
(\__/)
(")_(")
This is Bunny.Copy and paste bunny into your signature to help him gain world domination.
Sidney is offline   Reply With Quote
Old 10-09-2005, 09:44 PM   #5 (permalink)
badazztoyz
mach9's Avatar
View mach9's Photo Gallery
88 toy gears
hey i have some stock ring and pinions out of my 88. i took them out at 150k and they just been sittin here.
mach9 is offline   Reply With Quote
Old 10-10-2005, 12:54 PM   #6 (permalink)
slacker's Avatar
View slacker's Photo Gallery
2WD wont fit ... although it is an 8" , the bolt pattern is different .
slacker is offline   Reply With Quote
Old 10-11-2005, 01:56 AM   #7 (permalink)
View 85x2doa86alive's Photo Gallery
if all else fails, count the # of teeth on the ring and on the pinion. ring / pinion = ratio
85x2doa86alive is offline   Reply With Quote
