'88 pickup cold air - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 05-31-2005, 12:51 AM   #1 (permalink)
SovereignScorn's Avatar
View SovereignScorn's Photo Gallery
'88 pickup cold air
I've got an 88 with 22re, and recently I made a "ram air" system for it by doing some cuts my air intake with a dremel. I dont think the mod itself helped that much, but the fact that it gave the rest of the system enough air to take advantage of the other things i've done to the truck, I probably gained about 10-15hp. The system stays the same up to the mass air flow sensor and same. I'd like to setup some kind of cold air system, or atleast replace my hoses with pipes for even better air flow. Does anyone know where to get a cold air for this truck?
My "ram air" is posted below.
SovereignScorn is offline   Reply With Quote
Old 05-31-2005, 11:58 AM   #2 (permalink)
View Gear Dog's Photo Gallery
Home depot.
or you can just het some exhaust tubing and get some silicone hoses to fasten them. You can get the hoses with bends and reducers to make it work.
86 Toyota Pick-Up you know the one without a name
rusted and beige
Gear Dog is offline   Reply With Quote
Old 05-31-2005, 12:47 PM   #3 (permalink)
TOYO-MAN
View sonofmayhem's Photo Gallery
truckperformance.com has a downey intake for toy. and some other nifty stuff.
85, lifted and ready to rock!
sonofmayhem is offline   Reply With Quote
Old 06-01-2005, 03:33 AM   #4 (permalink)
View sefus's Photo Gallery
hotshot has an intake specified for a 93 22re truck but its the exact same. that one is the AEM version and pretty pricy but all kinds of bling. id say do your own for less money.
86 Toyota 4runner, 22re, 5spd: .02 over, head shaved for 9.5:1, full port and polish, 48/40 valves, dual valve springs, cam, header & exhaust, Supra AFM, SHO Taurus electric fan, removed AC, MSD 6a and coil, and a bunch of other little stuff
sefus is offline   Reply With Quote
Old 06-05-2005, 07:16 PM   #5 (permalink)
TOYO-MAN
got any pics of your intake setup? id love to see.
Old 06-05-2005, 09:48 PM   #6 (permalink)
JUST got the pictures uploaded:
http://img240.echo.cx/img240/4108/ra16zb.jpg
http://img240.echo.cx/img240/7384/ra25vp.jpg
http://img240.echo.cx/img240/2638/ra32zn.jpg
http://img240.echo.cx/img240/1705/ra46th.jpg
As you can see, when the grill is off the intake is exposed, so I had to cut the grill to get a direct flow of air to the intake. I went ahead and sprayed some black spraypaint there to mke it even harder to notice. From the factory, where the intake is open, there is a flap that blocks air from the grill, making air only acessable from under the truck. I left the stock air hoses, mass air flow sensor, and air box where they are, and put in a square k&n for better air flow through the box. At first, I was worried about water getting through the hose and into the engnie, but while I was putting in the new filter I realized that there is a small hole on the bottom of the air box, and the intake comes in under the filter. I grabbed a hose to test, and found that any water that goes in, comes out under the filter, and leaks out through the hole in the box.
The mod isnt hard and if you dont care about looks, is free. While I was doing this, I re-painted my grill so it cost me $10 for spray paint, clear coat, and sand paper. The cuts were done with an average dremel tool and bit.
Warning: I drive a rwd truck that never goes off road, so I dont worry about anything but dust, water, and the occasional bug getting through my grill. For all you with 4x4 trucks that go off road, you might want to consider making that hole a little bigger for mud, and getting some chicken wire and slim zip ties so you can drill some small holes around the intake in the grill to zip tie the chicken wire to so you can catch bigger peices of debris.
If anyvody tries this, tell us how it worked out.
