grinding when hubs locked in - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 06-28-2005, 01:44 AM   #1 (permalink)
Timota
snowboarder4lif's Avatar
View snowboarder4lif's Photo Gallery
Canada grinding when hubs locked in
hey, just wondering, I've got an 87 toy p/u with manual locking hubs and lately ('cause i'm stupid, and keep 'wheeling anyways) when I've been driving with the hubs locked in, occasionally I hear a metal on metal, or grinding noise. It isn't constant, and usually happens for brief amounts of time, but has gone on for longer, but seems to happen more when in 2 hi, with hubs still locked in than it does in 4 hi, and 4 lo. It seems to be coming from the drivers side, and no, it isn't rocks i've looked that far at least. anybody experienced anything like this before?
snowboarder4lif is offline   Reply With Quote
Old 06-28-2005, 11:47 AM   #2 (permalink)
Dads toy
Hermit's Avatar
View Hermit's Photo Gallery
You only hear this grinding noise when you have the hubs locked in 4wd position? Never when they are unlocked? Does this happen at all speeds or you only notice it at low speeds?
I'm just trying to pinpoint a diag. & solution.
*HERMIT*the T-Tech
"OH WHAT-A-FEELIN"
Hermit is offline   Reply With Quote
Old 06-28-2005, 02:01 PM   #3 (permalink)
View boo yah's Photo Gallery
I have a simmilier issue when the hubs are unlocked and at low speeds I hear a grinding noise Metal on metal. Like low brake pads. I checked the pads not the problem. I tried to take the hub apart but it rusted on pritty good. Any ideas? Other than have some one else do the work? the Axel seem a little sloppy.
boo yah is offline   Reply With Quote
Old 06-28-2005, 07:31 PM   #4 (permalink)
Timota
*HERMIT*the T-Tech
"OH WHAT-A-FEELIN"
it happens at all speeds, and yes, only when the hubs are locked in 4 wheel drive position, never when they are free. I'm not sure if it happens at a crawl, but definitely happens at higher speeds
Old 06-28-2005, 07:42 PM   #5 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
how many miles are on it. Over time, they may have jsut simply worn out. If you take it offroading, you may jsut want to invest in some new hubs to be safe. They're not overly expensive, and will give you piece of mind next time you go offroading. With locking hubs, you really shouldnt go highway speeds when hubs are locked and in 4WD. lots of un-needed wear occurs at highway speeds to hubs when they are locked and in 4wd. If you happen to get new ones, make sure you keep them unlocked until you need them.-- saves alot of wear on them.
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline   Reply With Quote
Old 06-28-2005, 08:09 PM   #6 (permalink)
Timota
yeah, it's up there on km's, but i definitely don't drive highway speeds with hubs locked in, i take them out usually as soon as I think I won't need them anymore, but thanks for the advice, I don't think the hubs are the problem tho, 'cause 4 wheel drive still works good. Think i'll just bring it into a shop, and see what they say.
Old 09-09-2007, 02:36 PM   #7 (permalink)
Performance Downgrade
Shogun1011's Avatar
View Shogun1011's Photo Gallery
similar issue!!
Hey all,
I'm having a similar issue. Happens in 4 hi...on and off. Sounds almost like sand grinding somewhere. doesn't happen at all in 2hi. Also never noticed it in 4lo.
If anyone has gotten to the bottom of this, i'd love to know the answer/solution to fixing it.
Thanks,
Shamus
When God said 'Let there be light' Chuck Norris said 'Say Please.'22rte,Bored.030,P&P head,frgd pistons,CompCam,K&Nfilter,CressAFM,Garret t3/t4,MBC,FMIC,BOV,440ccInjectors,Flowmstr,FAST A/F,EGTgauge,BoostGauge,SAS w/82front axle,xover,Cust. drvshft,AllPro,ProComp,RollBar.amsoil,93octane
Shogun1011 is offline   Reply With Quote
Old 11-12-2007, 12:56 PM   #8 (permalink)
87zombie's Avatar
View 87zombie's Photo Gallery
Canada
I'm having a similar problem. Only when the hubs are locked, dosen't make a difference if in 4wd or not. It sounds like something is rubbing on the tire. I cleaned and relubed the hubs but it didn't make any difference. It comes and goes, it is speed related as it slows to a stop as the truck does. Any thoughts?
87zombie is offline   Reply With Quote
Old 11-12-2007, 01:09 PM   #9 (permalink)
Shogun1011's Avatar
sorry! no luck yet
Sorry...no luck yet. It's been a couple months since i posted my response, and nobody seems to know...or they don't care to post an answer.
If you do figure it out, i'd love to know what the solution is.
Thanks!
Shamus
Old 11-12-2007, 02:27 PM   #10 (permalink)
87zombie's Avatar
I read on some other sites that it could very well be dry spindle bushings. The description others had were exactly the same as mine. I will lube mine and let you know what happens. Some guys are changing the bushings to roller bearings but there seems to be many saying that is a bad idea. Re-lube bushings and you are done, if bearings dry out it can cause lots of problems. Plus if you get water in there (like we would ever go in water...) they could rust causing problems too. So keeping the bushings and lubricating them seems to be the way to go. I will repost when I get them done, it might be a few days though... have to find a 54mm socket.
Old 11-12-2007, 05:36 PM   #11 (permalink)
View HLN 85 Yota's Photo Gallery
I sometimes feel a vibration when the hubs are locked but i soon found out that it was the front drive shaft joints. They were worn out. Causing the driveline to be very sloppy when it rotates.
22r 85 toyota regular cab
31in tires on black rims
HLN 85 Yota is offline   Reply With Quote
Old 11-13-2007, 09:53 AM   #12 (permalink)
87zombie's Avatar
I may have that problem too but the other is more important to fix right now. I didn't notice any vibrations until I raised the sagging rear last week though. About 5 inches in lift using extra leafs.
Old 12-22-2007, 07:32 PM   #13 (permalink)
pooky112404's Avatar
View pooky112404's Photo Gallery
mine makes popping noise when i backup in any 2hi 4hi 4low don't matter hubs locked or not help please
pooky112404 is offline   Reply With Quote
Old 12-23-2007, 10:11 AM   #14 (permalink)
Official TN Asshole
seandnw's Avatar
View seandnw's Photo Gallery
change out the hubs..
85' 22r. 4x4...some stuff
www.myspace.com/suckondeezforafew
seandnw is offline   Reply With Quote
Old 12-24-2007, 01:11 PM   #15 (permalink)
87zombie's Avatar
Just an update. I lubed the spindle bushings and the problem is fixed.
