No Brakes!!! Need Help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 09-28-2005, 09:43 PM   #1 (permalink)
View csm672's Photo Gallery
Hi, I have an '85 Toyota 1 ton 2WD. It has a braking problem that I can't seem to fix. It started about 3 months ago. I would pull up to a stoplight and my brake pedal would slowly go to the floor. Now it has progressed to the point that when I push the pedal I get good brakes for about 1 second and then the pedal hits the floor and I have no brakes. I had a leak in my load sensing proportioning valve (I think- It had some fluid in the boot) so I replaced it today. I went to bleed the brakes and can't pump them up enough to bleed them. The pedal goes straight to the floor. I get fluid to every line but it just won't hold the pressure on the brakes very long. I did notice today that with the engine running, when I pump the pedal rapidly the idle gets rough. This has to be the booster. I unplugged the vacuum line and plugged it up and it ran fine when I pumped the pedal (but maybe this is normal- I don't know!) I have no leaks and am pretty certain all the air is out of the system. Could a booster cause the problem I'm having? The master cylinder was replaced a couple of years ago, but maybe it is bad? Any help would be greatly appreciated. Thanks, Casey
csm672 is offline   Reply With Quote
Old 09-28-2005, 09:50 PM   #2 (permalink)
TOYO-MAN
View sonofmayhem's Photo Gallery
i had the same problem with my 85 1/2 ton, i replaced the master cylinder and they work like a dream.
85, lifted and ready to rock!
sonofmayhem is offline   Reply With Quote
Old 09-29-2005, 11:11 AM   #3 (permalink)
View smasheromalley's Photo Gallery
The sinking pedal problem is probably the brake master cylinder. Ive run into it a handful of times over the years and it has always been the brake master cylinder.
'87 1ton dually C/C
injected 22-RE 4-speed 4x2
smasheromalley is offline   Reply With Quote
Old 09-29-2005, 07:22 PM   #4 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
I'll 3rd that on the master cylinder vote. My LSPV was also leaking and dealer wanted over $200. Been running without it for the past 6 months. I did replace the master cylinder for the same symptoms that you are having.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline   Reply With Quote
