anybody else have alternator belt problems??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum > Pre-88 Toyota Pickup/Hilux
Pre-88 Toyota Pickup/Hilux Discussion area for the '88 and older Toyota Pickup/Hilux. NEW!
Old 09-30-2005, 06:16 PM   #1 (permalink)
View smasheromalley's Photo Gallery
When I first got my truck the alternator belt was so loose you could just about spin the alternator pulley with the engine OFF.
I replaced both belts and this will be the 3rd time Ive had to tighten the alt belt inside of 6 months. WTF?? Are the parts stores stocking the wrong belt for this thing?
Anybody else had magically loosening alternator belts in their trucks?
'87 1ton dually C/C
injected 22-RE 4-speed 4x2
smasheromalley is offline   Reply With Quote
Old 10-01-2005, 01:28 AM   #2 (permalink)
View 85x2doa86alive's Photo Gallery
not to sound like a dumb question, but... did you tighten both bolts? there is the pivot and the keeper... if you leavee one loose, it could loosen up the belt. just a thought
85x2doa86alive is offline   Reply With Quote
Old 10-01-2005, 09:57 AM   #3 (permalink)
Yep Im sure I tightened both bolts. The only thing I wish I would have done is marked the adjuster slide to see if its the alternator thats loosening up or if the belt is stretching/wearing. I guess its possible that I havent been tightening it enough
'87 1ton dually C/C
Old 10-01-2005, 10:24 AM   #4 (permalink)
82toyo's Avatar
View 82toyo's Photo Gallery
You might want to make sure that the slide adjuster is not loose. I had the same problem and everything was tight and could not figure it out. I finially found that where the slide bolts to the block was missing the bolt. Rebolted it and everything has been fine since.
82toyo is offline   Reply With Quote
Old 10-02-2005, 01:48 PM   #5 (permalink)
ac3nigthmare's Avatar
View ac3nigthmare's Photo Gallery
the parts store buy my house did give me the wrong size it was way too tight my altinater had to be moved as close to the block as possible to get it on, it works but dont just throw away the wrong belt idea
Its a work in progress...
ac3nigthmare is offline   Reply With Quote
