Toyota Highlander - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 1st Generation (2001–2007)
1st Generation (2001–2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
Old 07-27-2003, 12:00 AM   #1 (permalink)
VIP
View SILVERROLLA's Photo Gallery
Exclamation Toyota Highlander
I HAVE AN 03' HIGHLANDER. WHEN EVER I TURN THE KEY ALL THE WAY TO THE START POSITION BUT DONT START IT, I HEAR A BUZZING NOISE OR SOME KIND OF ELECTRICAL WIRE BUZZING. IT SOUNDS DANGEROUS. ALSO WHEN I TOOK MY CAR TO THE DEALER, THERE WAS A RECALL ON THE CAR ABOUT THE EXHAUST CLAMP OR SOMETHING. THEY HAD TO ROTATE IT?? ANYWAY, NOW THE MUFFLER MOVES MORE THAN IT SHOULD BE AND I AM WONDERING IF IT IS LOOSE.?? NEED HELP
SILVERROLLA is offline   Reply With Quote
Old 07-30-2003, 01:19 AM   #2 (permalink)
Darren's Avatar
View Darren's Photo Gallery
Re: Toyota Highlander
Originally posted by SILVERROLLA
NEED HELP
This might:
Darren is offline   Reply With Quote
Old 07-30-2003, 01:30 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
the noise is your fuel pump getting the pressure back up in your system
i have no clue what the hell you're talking about with the muffler though
maybe you should ask whoever fed you that crap at the dealer
oh and yes, typing in all caps is VERY annoying
-Nick
Nick is offline   Reply With Quote
Old 08-01-2003, 01:00 AM   #4 (permalink)
View 1GR-FE's Photo Gallery
the recall was actually fuel related they need to check the position of the fuel line clamp if it is pointed up then it simply need to be rotated into the proper position, technically u are supposed to lower the gas tank but u dont need to, however if they did lower yer gas tank then an exhaust support might be loose causing yer muffler to move slightly look under the car and see if u can see any rubber exhaust mounts loose, if so take it back to the dealer and be nice about it every1 makes mistakes
1GR-FE is offline   Reply With Quote
