Steering and Alignment Problem on my '03 Highlander - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 1st Generation (2001–2007)
1st Generation (2001–2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
Old 09-14-2003, 04:48 PM   #1 (permalink)
View HiLander's Photo Gallery
Suspension/Steering Adjustments on Highlander?
I am the proud but disappointed owner of a 2003 Highlander Limited 2WD. Ever since I bought my car, there has been a pull to the left and the steering wheel was off-center. Such had been the case with my 2001 RAV4 and my 2003 Camry, both of which were fixed without issue.
My car now has 1000 miles on it. I have taken my car to Bell Road Toyota in Phoenix twice now for adjustment, and there is still a pull to the left, considerable bump-steer, and wandering on straightways especially at freeway speeds. On center, the steering feels disconnected and sloppy. They assure me that everything's "within spec." The service manager thinks I'm crazy and he sees nothing wrong with it. In a test drive of 4 miles I don't see how he could make that determination.
Upon researching my car's symptoms on the internet, it appears that the camber settings could be the culprit. I got a printout of the alignment settings from the dealer and the left front camber is at -0.3 degrees and the right is at -1.1 degrees. The rear camber is (left) -1.0 and (right) -2.1. For the record, toe settings are at an exact 0 degrees on both sides in the front and +0.16(l)/+0.17 (r) in the rear so I don't think toe is the culprit.
At first glance of these stats, it would seem obvious there's a bias to the right in terms of negative camber which would force the car to drift left. The problem is that the service manager says there is no camber adjustment on the '03 Highlander. Is this true, or could be he just be misinformed?
Anyone out there have more info for me? Am I on the right track?
HiLander is offline   Reply With Quote
Old 09-15-2003, 08:50 AM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Can you post a picture of the steering setup? That will help me understand what needs to be done.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline   Reply With Quote
Old 10-30-2005, 05:17 PM   #3 (permalink)
View 91mr2's Photo Gallery
Highlander alignment problems
OK so I'm two years late on this post but I'm new to the forum...better late than never
I had a similar problem on my 02 highlander. Turns out there was a defect in the belts of the Goodyear Integrity OEM tires. My dealer called it radial pull and is covered by the goodyear warranty. The tire was on the passenger front. I rotated it to the rear of the car and no more problems. Didn't even bother with the warranty because it's a pro-rated deal and I wasn't going to spend another cent on a replacement Integrity.
I recently got rid of the pathetic Goodyear Integrity tires for a set of Bridgestone Dueler Alenzas which are far superior.
91mr2 is offline   Reply With Quote
Old 11-04-2009, 11:38 PM   #4 (permalink)
Gameroom cash: $265140
View shortlid's Photo Gallery
Question Camber adjustment
Is there any front camber adjustment on our trucks. The rear seam only to have toe adjustment cams also??
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row, now has 125k on the clock.
My family in-law has a '97 Tercel CE Coupe, '03 Tacoma DC, '07 Highlander V6, 4WD, 7 pass. and a '04 Sienna LE!
shortlid is offline   Reply With Quote
