2002 Highlander issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 1st Generation (2001–2007)
1st Generation (2001–2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
Old 12-27-2003, 10:22 PM   #1 (permalink)
View Locopelli's Photo Gallery
Two questions to see if anybody else had had these issues- one being minor and the other perhaps more crucial.
The minor: the recycle air function will on occassion turn itself OFF. I have seen this happen after pushing the odometer button or changing the temp or ???. None of these triggers are 100% reproducable which makes the ghost in the machine that much more annoying. So in a nutshell, the air recycle function green light will be on one moment and then the next time you look it is off.
Of greater concern to me is a new issue pertaining to the ABS breaks. Yesterday after nearly having a crazed Chevy Alavanche driver kill my entire family, which required a serious breaking to avoid a headon collision, my ABS now makes an extra noise other than the mechaninal clamping noise I had noticed on a previous, less dangerous but more snowy occasion. Tonight while driving on some back streets with spotty ice the ABS would engage and in addition to the normal clamp, release, clamp, release, etc noise there is a grinding/whining/godawful noise that makes me suspect some kind of damage was done to the ABS function.
Obviously I need to have the vehicle inspected but I would like some input regarding either condition from anybody that has prior experience with these issues so I have something to weigh against the dealer's findings.
TIA for any insight into these issues- I appreciate it greatly.
Jason
Locopelli is offline   Reply With Quote
Old 12-28-2003, 08:43 PM   #2 (permalink)
VIP
View SILVERROLLA's Photo Gallery
The air reclycle turns off itself becasue its been on too long or the power surges in your dash is weak as u state wen u push the odod light, the aire recycle turns off... check the electrical
Now for the ABS, get your system checked. Pads,Rotors, etc... ALl noise u hear is normal but if u r that paranoid about the noises, be safe and get it hecked out. Better safe then sorry
SILVERROLLA is offline   Reply With Quote
Old 01-02-2004, 12:41 PM   #3 (permalink)
The air recycle answer seems logical enough I will look into that.
As for the ABS issue I am having the dealer look into it at the next scheduled service. Normally I am paranoid about such things but I did some additional "brake testing" on dry pavement and the normal noise was present compared to the more dramatic noise I experienced on the ice. So at this point I am concluding the additional noise on the ice was due to the ABS and the VBS having to work harder/longer to attempt to get the job done, which was more difficult that on dry pavement obviously.
Thanks for the insight.
Jason
