03 Highlander P0171 & P0174 - Toyota Nation Forum : Toyota Car and Truck Forums
1st Generation (2001-2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
post #1 of 4 Old 05-27-2009, 06:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question 03 Highlander P0171 & P0174
Hello everyone. I have an 03 Highlander with these two codes (P0171 & P0174 sysytem lean). It does not want to start unless I spray carb clean in the throttle body. It stays running after that (I haven't tried take it on the road). I was told to replace the fuel filter but I see some comments in the forums that say these fuel filters never go bad. Any suggestions?
jacsr is offline
post #2 of 4 Old 05-28-2009, 09:20 PM
Highlaner Dude
Recovery's Avatar
Quoted: 2 Post(s)
These codes according to the toyota repair manual are "system too rich". It sounds like your "Intake Idle Air Control Valve". After years of running these can get carboned up. You can try to remove the IIACV and clean it with carb and choke cleaner then reinstall it. This has been known to fix it. If it doesn't you will needs to replace the unit. My 02 had a problem of not starting and uneven ideling, I could get it to start by pumping the pedal. I cleaned the unit and it is working perfectly a year later. Hope this helps. If it does just go to Auto Zone or Advance Auto and they can delete the codes once you fix the issue for free.
Recovery is offline
post #3 of 4 Old 05-28-2009, 10:09 PM
Quoted: 0 Post(s)
Also check the 2 wires down in the MAF sensor for dirt build-up etc...
05DCLB is offline
post #4 of 4 Old 05-29-2009, 09:33 AM
Toyota Traitor
Quoted: 11 Post(s)
My 2002 had this problem, 2 air/fuel ratio sensors and a new o2 sensor solved the problem.
2015 Acura RDX V6 AWD Tech
2009 Toyota Tacoma AC V6 SR5 w/PP
2008 Honda Civic LX-SR
departed.. 2002 & 2008 Highlander V6 AWD..
AXMACD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 1st Generation (2001-2007)
User Tag List
Linear Mode Linear Mode
« Back
