Transmission drain & refill 2001 V6 AWD PART ONE
36K views 23 replies 10 participants last post by  Dante's Taco
Changing the Transmission + front diff Case Oil (2001) - Yes, they are all one unit.
Here is a write up on changing your own transmission case oil, with a few pictures. It is aimed at someone with very basic wrenching skills (but perhaps not a complete novice). Nah - scratch that - this is *easier* than an oil change!!!:D
As always... some safety points first when working under a vehicle:
  • ALWAYS make sure vehicle is either level, or if on ramps, will not roll towards you if something fails with brakes or wheel chocks
  • engage E-brake
  • chock at least 2 wheels to prevent rolling
  • rubber gloves are nice
Regarding the usual question: "Do you need to do this on a lift?" - no, just like a couple of weeks ago rear diff oil change, I did this in the garage (in Winter, I mean Spring - haha wait till you see the pics at end). But I did run the vehicle up on 2 inch cedar blocks.
here is the supply list:
Tools
- 10mm Hex head socket to remove Drain plug
- Ratchet
- Torque wrench
- big oil pan to catch old oil
- new double-capped long neck oil funnel - dedicate to ATF only - preferably one with a fine screen in it to ensure nothing bad gets in.
- May need a snipe or breaker bar to get the plugs loose (depending on how long since this was last done)
Misc
- Ramps (optional)
- Oil Pan
- Paper towels or rags
- Rubber gloves
- Wheel chocks
Consumables:
You will need about 3.9 litres of Type-IV Toyota ATF oil (4 jugs). Mobil ATF 3309, or Amsoil ATFQT also works - there may be others)
- and 1 plug aluminium washer - Toyota part # 90430-18008
This is Part I, as I plan to let this fluid circulate, then maybe pop the tranny pan & check magnets / oil pickup screen (& re-fill of course) ;)
Here we go; the big double box-end wrench is NOT for use on the drain, it's my "breaker bar" :
Here's a view from the front; you can see it on blocks:
Closer view of Tranny pan:
And there it is: needs a 10 mm hex-head socket to loosen:
Before you loosen drain, pop hood/bonnet & find the orange dip stick (also our filler tube) :)
Of course you want to know... is it still Winter here??? That there Gold Taco 2006 is mine, being air'd down... for a day of fun in the sun with REAL 4WD (just kidding)
get ready to drain: bucket in place, 10 mm hex on socket, & GO!
Out comes the bad:
Here is the drain plug:
Cleaned-up with new washer:
Replace plug & tighten down to 36 ft-lbs spec:
This is what it looks like once tightened:
Now, take fancy funnel & put one end down tranny dipstick/funnel hole:
Other end ready to receive oil:
Fill it up. Use 3 full jugs & then maybe 1/2 of last one, before you check level:
I let the funnel system sit in place a while to drip-dry:
To check level, you must have engine running and on a level surface. Shift through all gear points a couple of times. A dry tranny dip-stick looks like this:
After almost 4 litres of ATF, and a few trips around the block, it looks like this (not really hot, nor cold yet.) Will need to check over the next few days to fine tune level. Now you see why a dedicated ATF funnel with capping ends is nice :D:
Comparison of old TF on the right, and new on the left:
Old on paper towel:
New on paper towel:
Well, there it is folks. Check the level when both cold & after a good long drive & see where it's at. I'm going to let it sit in for a few 100's to 1000 km, and then repeat again. Under the premise that this new fluid will act as an infusion of detergents & hopefully get any deposits suspended for the next drain & refill.
Part two gets a little technical.. (that's if I drop the pan to check on the status of the pick-up screen & pan magnets). Some of the pans bolts are pretty blocked by the cross-member.
Dante
PS here is my playground:
Snow is still pretty deep:
Another great write-up!
When I changed mine at ca. 60,000 miles I definitely needed extra leverage to get the drain plug off. The dealer did a "flush" at 30,000 miles and probably did not remove the plug.
I also used a full 4 quarts of fluid to get it up to the correct level.
And that goes ditto for me, thanks buddy! :chug:
Hi
1) so, no you are not ever going to go from the horrid brown in the 100 mL beaker, to the wonderful pink factory-fresh fluid in the 50 mL beaker with just 1 simple drain & refill. Even doing multiple ones, you will never get all the old out. In pharmacy, this is what we call Serial Geometric Dilutions. Say, for the sake of argument, the first drain & refill gets 50% of old out. Then 2nd only gets 50% - but of the blend of old & new, so only 25% actually. Worse, 3rd is down to 12.5% & so on - you rapidly reach a point of diminishing returns. The paper towel that looks so pink is after a few trips around the block - a lot of brown fluid was still prob. in the torque converter.
2) I haven't done part 2 yet, b/c I only just did part 1 this last Friday :)
Let's give the new fluid a while to scrub away any gunk, as I mentioned...
I think the reason you can't get *all* the old fluid out, other than by draining out a cooler line while topping up (all the while with engine running) until fluid out is as pink as fluid in, is why people like to think the infamous tranny "flush" is a good idea. But I've repeatedly discussed this with my 'Yota tech friends, and they are adamant - Toyota does NOT recommend tranny flushes routinely.
Lenore can probably jump in here & explain better than me why that is :)
owns 2023 Toyota Camry XSE Hybrid
Dante does your tranny have the second drain plug located on the transaxle just behind the oil pan on the inside (engine side) of the tranny? The RX300 had this plug and when you undo it even more fluid comes out...It still fills from the dipstick to the main tranny.
#11 · (Edited)
Hi lenore.
Thanks for bringing this important point up. When I first began researching this DIY, I started on the Club Lexus Forums. Where it became quickly apparent that the RX 300 is NOT identical to a 2001 Highlander. Can't speak for a Kluger - Matt?
Here's why: Compare the pic you posted in the link, to these actual pics taken tonight, under my HL. Note the casting mold 'spot' where a front diff drain would be. Note how there is also no such drain.. :cool:
I guess the Lexus still kicks our ass is some ways, eh?
Yes, I know I might have a mild front diff oil leak - but it is *very* slow, so until I'm ready to pull a diff apart, I'll live with it :D
Cheers dude.
PS - this info was verified with a Master Toyota Tech. To Repeat - Highlander 2001 AWD DO NOT have a separate front diff drain.
D
#13 ·
High grandpa.
No, the Transfer case on our HL has lots of cooling fins on it - see my DIY on the transfer case oil change, and you will see what it looks like.
That conical metal chamber, with the oil "stain" is the front differential, and it is an integral part of the transmission - they share the same fluid. On the Lexus RX300, it actually has a drain plug, as well as the tranny drain pan. People have verified that these two share the same fluid, by pulling the (Lexus's) front diff drain plug, adding fluid through dip stick, and it will come out the open drain plug for the front diff.
In our HL, the fluid circulates somehow - but I do not have a FSM yet, so do not have schematic. But it (front diff) does take T-IV transmission fluid, just like it's co-part, the transmission.
This type of set-up is referred to as a "transaxle"
And yes, it would appear I have a very minor oil leak in my front diff. I will power wash it off & inspect it's rate of progression. I t appears stable or at least very very slow.
cheers. Feel free to keep asking! :)
#14 ·
Great write up thanks for taking the time to do this. I just ordered everything to do the transmission fluid in my 01. I've been wanting to do it and this post made it so simple I could not resist! Thanks again!
#16 ·
Side note: I've heard other's refer to fins on transfer cases and diff cases as "cooling fins". I *think* these are present to provide structural rigidity to cast housings, not for heat dissipation, per say.....
#18 ·
I think I referred to them as cooling fins. I assumed that b/c there were so many of them, and it's a viscous coupler, so I expect a fair amount of heat generation in the T-case with that set-up.
But I'm open to be corrected if that's not the case.
#17 ·
Yeah, I can show you the colour - will do so later tonight or tomorrow.
Part II is on hold while we sell house. We list on Tuesday, and you basically have to able to leave on a moment's notice. not exactly the time to be disassembling the wife's tranny pan :lol:
Once in new house will do it. Instead, might just drain & refill another 4 quarts in the meantime; but you don't need me to take pics of that again.
G
#19 ·
Whoops.
Forgot to post up that colour after the first drain & refill - sorry.
Here it is as of last week - just did a second drain & refill:
Brought to you by Alexander Keith's India Pale Ale :lol:
Not so sure I want to drop the pan on this tranny now. A few of the bolts will be a bitch to get at, and no-one is recommending it amongst the techs I know. So it's on the "could be done, but won't be done for now" list.
Preliminary fluid checks show Very Cherry colour now.
Geoff
#21 ·
Yes, interesting that they have that kind of faith in T-IV fluid.
I thought that given the low cost & ease (as far as a DIY goes) that a few drain & fills, if of no benefit, would not hurt (as opposed to a flush, which could).
My fluid was very dark before I did these two drain & fills - it sure is a lot lighter red now.
Does colour mean anything overall though? It didn't smell burnt, which is one thing I've seen first hand on another vehicle.
Anyway, like I said, this is the easiest fluid change on the whole vehicle, so not one I'm going to skimp on
cheers
G
#23 · (Edited)
100% agree. This kind of proactive maintenance on a $4000+ transmission makes a lot of sense given the ease of AT drain and refill and the relatively small investment in a case of AT fluid. I do an 4 quart AT drain every 15 k - basically a 15-20 minute job.
The Highlander is so easy to change fluids on - I did an oil and filter change in about 30 minutes this weekend - no need to even use a jack.
I guess that makes up for the fun to be had in changing the rear bank spark plugs? And that engine air filter housing is also a beaut to mess with....Pandora's box.
#22 ·
@ dante's taco:
i just dropped my tranny pan two weeks ago to change gasket and filter adn clean magnets. (127k on car). in reference to those few bolts to get at... yes they are a pain. here's what i learned from my own experience and this site. use a box wrench on the two bolts buried behind the A frame and a small 1/4" rachet on the 2 or 3 bolts in front of them.
i found that by putting the car up on jack stands and then placing a jack under the tranny and jacking it to the point where it almost lifted off the jackstands raised the tranny enough to make removing those few bolts more bearable.
someone said torque the bolts to 59 inch pounds (yes inch pounds). since i don't have a torque wrench i went old school by feel. after a week of driving everything was bone dry and looked great.
i too have a little weepage going on where the case joins the tranny. it is so insignificant. i also noticed a little bit of dampness where the transaxle arm comes out and goes to the passenger's side.
i might throw some auto-rx in the tranny to internally clean.
i did a home made tranny flush as well. i disconnected the hose that comes OUT of the tranny cooler and ran some clear plastic tubing from the cooler into a bucket. armed with 11 qts (the tranny holds 10) i had my neighbor run the car while I poured fresh fluid in the tranny. worked like a charm. i used the castrol multi import fluid.
hope this helps.
#24 ·
Thank You! I missed this - sorry didn't reply. had some, er... Telecommunications Issues (Yes, Telus, this means you) during the move so was off the grid for 7 days & missed this. Armed with this new info changes things.
Hmmm...
