How hard is it to install factory foglights to highlander? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > 1st Generation (2001–2007)
1st Generation (2001–2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
Old 01-14-2005, 06:51 AM   #1 (permalink)
View SUla89's Photo Gallery
I got an 05 highlander V6 4x4, it came without fog lights. Is it hard to install the factory ones in those two cavities for the lamps?
I talked to the service department of a dealership and they said it's gonna be real hard because of the wiring.
SUla89 is offline   Reply With Quote
Old 03-11-2006, 07:11 PM   #2 (permalink)
View mik00725's Photo Gallery
I did on a 2002 Hihglander. Parts needed:
Foglight lamps(original)
Tacoma 2001 fog light switch
Bulbs for the lamps (they must be OEM I tried buying replacement and they didn't fit)
Fog lamps "studs"
I've all parts number but not here right now.
I did my own wiring with a BOSCH relay and connected to the Tacoma switch. A guy at the dealer i take the truck for oil change couldn't believe it wasn't an original installation. It all depends on your installation ability and attention to details.
mik00725 is offline   Reply With Quote
Old 03-13-2006, 09:56 PM   #3 (permalink)
View Turbolovin84's Photo Gallery
next time u have soem free time and a ratchet with a 10mm, remove the covers below the fog lights and some Toyota's came "pre-wired" for foglights, when u look under there and see a connector tied back to the bumper frame ur pre-wired, all u would have to check from there is in the steeering wheel all the way behind the light switch would be a another connector zip tied away from anything, just purchase the foglights, a fog light/headlight stalk and maybe fuses and or relays. HOpe that sorta helps
Turbolovin84 is offline   Reply With Quote
