2001 Highlander tune-up suggestions.
Hi guys,
I'm a proud owner of a '01 Highlander I6 AWD, and i've hit about 60,000 miles.
What do you guys suggest I do to tune it up. I haven't done anything yet besides changing the oil, oilfilter, air filter, breaks, and tires.
I was thinking about doing a transmission flush and coolant flush about now. What other things are *really* important to be done? I've read something about some 'transfter case oil' but dunno what that's for and how important it is to change. I've seen in the manual it says to 're-torque drive shaft bolt' or something like that.
Well, the place i found for the trans flush will do the following: Using the 'T' machine, it will put in new fluid as it takes out the old fluid, but they *will NOT* drop the pan. Should i take it elsewhere and have them drop the pan to replace the filter, or do i need not replace the filter?
What trans fluid should i use? - Toyota's or something else?
Well thats it for now, thanks for any helpful suggestions!
