'04 highlander - won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 1st Generation (2001-2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
post #1 of 10 Old 11-23-2009, 11:40 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The battery died on my highlander. We replaced it, but now the highlander won't start. The red light next to the steering wheel no longer flashes. Do I need to reset something since we had to replace the battery? We know the battery was dead previously because none of the electrical would work, but since we've replaced it the electrical works again.
DiAnne82 is offline
post #2 of 10 Old 11-23-2009, 12:01 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3749 Post(s)
to Toyota Nation!
Make sure the contacts at the end of your positive and negative cables are clean. Use a wire brush to clean any corrosion off of them and you've got clean metal to metal contact. Most often, that's why a vehicle won't start after changing out a battery.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now
post #3 of 10 Old 11-23-2009, 12:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Originally Posted by TrailDust View Post
to Toyota Nation!
Thanks!
If this was the problem would I still be getting power? Our lights work (and they didn't before switching out the battery).
DiAnne82 is offline
post #4 of 10 Old 11-23-2009, 12:32 PM
Do you feel lucky?
TrailDust's Avatar
Batteries are funny that way. It's possible...IMO...for you to be getting enough juice for lights but not enough to turn the engine over. Are your contacts clean? If not, make sure they're clean and make sure they're tight on the battery posts. If that doesn't do it I'd try taking the battery back. On rare occasions a battery can come with a bad cell that will provide some juice, but not enough to turn over an engine. If a battery swap doesn't do it, then there's a deeper issue involved (alternator, etc.) that will require servicing. Always start with the simplest troubleshooting causes and work your way up.
2002 Avalon XL
post #5 of 10 Old 11-23-2009, 03:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I checked for corrosion on the contacts, and they are clean.
My theft deterrent system/engine immobilizer system indicator light does not flash when the key is out of the ignition, but everything I'm reading says it should. Does something need to be reset?
DiAnne82 is offline
post #6 of 10 Old 11-23-2009, 03:40 PM
Senior TN Member
Quoted: 1 Post(s)
Sounds like it, my '04 the Imobilizer flashes any time the key is not in the ignition.
Use to work for TMMI, own a '04 Highlander V6, 4WD, 3rd row,155k. My family in-law have over 5 Toyota vehicles!
shortlid is offline
post #7 of 10 Old 11-24-2009, 10:12 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
One more thing I didn't mention. When we got our new battery, it was labeled wrong (and thus we hooked it up backwards). We exchanged the battery for a properly labeled one, but could hooking up the battery backwards caused some sort of problem?
DiAnne82 is offline
post #8 of 10 Old 11-24-2009, 11:25 AM
Senior TN Member
Quoted: 1 Post(s)
Exclamation Oh Yes!!
Yep, reverse polarity with new computer systems on board and do all kinds of damage! I hope a fusable link prevented anything real bad.
shortlid is offline
post #9 of 10 Old 11-24-2009, 11:36 AM
Do you feel lucky?
TrailDust's Avatar
Agree with what shortlid said. This is one of the most common mistakes, but it's one of the most costly ones too. Modern vehicles are a multitude of computers on wheels, and when you reverse polarity on a new battery the result is typically fried computers. At this point take your car in to be serviced, preferably at a local mechanic as opposed to a stealership.
2002 Avalon XL
post #10 of 10 Old 02-05-2010, 07:28 AM
alotawatts's Avatar
Quoted: 1 Post(s)
Late reply....but I have a feeling this did not have a happy ending..?
I've never seen polarity labled wrong on a battery....it's embossed in the case molding.
DOH !
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 1st Generation (2001-2007)
User Tag List
Linear Mode Linear Mode
« Back
