Brake Caliper Slide Pin Confusion - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 1st Generation (2001-2007) Forum dedicated to the discussion of 1st generation Toyota Highlanders.
post #1 of 9 Old 06-10-2012, 07:31 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I recently replaced the rear brake pads on my wife's 06 Highlander. There are two different slide pins used; one has a rubber bushing on the end and the other doesn't. This is the first time the brakes have ever been serviced so things are exactly the way they were when vehicle left the factory. The slide pin with the bushing came out of the top position. I have the Toyota factory service manual. It says the slide pin with the bushing goes on the bottom. What gives? And what does that little rubber bushing do anyway? If they're helpful or needed why doesn't Toyota just use pins with bushings? This is the kind of stuff that drives me batty.
BikerBill is offline
post #2 of 9 Old 06-11-2012, 10:28 AM
camrybill15's Avatar
Quoted: 10 Post(s)
Don't know the purpose of the rubber bushings but I replaced my rear pads on my '04 Highlander about a year age and the slide pin with the rubber tip was on the bottom. I bought the car new and that was the first time the pads had been changed.
formerly cmryhldr
2015 Camry SE 4 cyl. 2AR-FE
camrybill15 is online now
post #3 of 9 Old 06-13-2012, 07:43 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Not Just a Toyota Problem
I did some web searching and found that owners of Subaru, Nissan, and I think it was Honda products report the same problem: their factory service manuals say the slide pin with the rubber bushing belongs in one position and the reality of their vehicles is just the opposite. I'm guessing there must be one dominant supplier of brake calipers to the Japanese manufacturers and somewhere along the line they changed the location of the pin with the bushing on it and the service manuals didn't catch the change for a while. I still have no idea what the function of the bushing is. Just another one of life's little mysteries....
post #4 of 9 Old 06-13-2012, 02:38 PM
Quoted: 15 Post(s)
flux capacitor holdback bushing
edwardh1 is offline
post #5 of 9 Old 06-16-2012, 12:58 PM
Registered User
Quoted: 0 Post(s)
There may have been a problem with vibration causing noise. The bushing would help to reduce that.
IBME is offline
post #6 of 9 Old 10-21-2012, 11:14 PM
Quoted: 0 Post(s)
My daughter's 2006 Highlander has the pins with the rubber bushing in the top position on both sides. I believe they eliminated chatter or rattle when the brakes are released and traveling.
JoeFoss1 is offline
post #7 of 9 Old 04-18-2013, 01:23 PM
Quoted: 15 Post(s)
where can you find pictures of where the pins are in the caliper?
edwardh1 is offline
post #8 of 9 Old 04-18-2013, 08:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
edwardh1,
Send me your e-mail address in a private message to me. I can scan some images for you via e-mail. I cannot post pictures here on this forum.
Bill
post #9 of 9 Old 04-29-2014, 11:49 AM
Quoted: 15 Post(s)
any updates on this subject?
edwardh1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 1st Generation (2001-2007)
User Tag List
Linear Mode Linear Mode
Back
