RAV 4 Tire Pressure Sensor, Won't go off!? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > RAV4 Forum
RAV4 Forum Looking for RAV4 information and resources? This forum is the place.
Old 09-04-2007, 09:06 AM   #1 (permalink)
View Matrix Monster's Photo Gallery
so it seems as though my daughter is having trouble with her '04 RAV tire pressure sensor... The dealer fixes, get the light to go off, by resetting it with the whole odometer trick... BUT theeeeeen it comes back on and even with us having the tires pressured up to their rec. pressure... Anyone have an idea as to what might be going on...? I would really appreciate any help... the light is more of a bother than a necessity...
Matrix Monster is offline   Reply With Quote Quick reply to this message
Old 09-09-2007, 07:14 PM   #2 (permalink)
wonger's Avatar
View wonger's Photo Gallery
is it solid on or flashing
if it is just solid on.. than make sure your tire pressures are set evenly.. i do like 35-36 psi cold..
wonger is offline   Reply With Quote Quick reply to this message
Old 09-10-2007, 03:58 PM   #3 (permalink)
View da_jazzee's Photo Gallery
Sorry if these suggestions seem simplistic, but……
Did they check the spare tire pressure/sensor.
Were the tires ever replaced/dismounted from the wheels; maybe a sensor got damaged in the process.
The batteries in the sensor are supposed to last 10 years, so with only three or so years on yours that shouldn’t be the problem, but who knows.
Sorry can’t offer better than this.
da_jazzee is offline   Reply With Quote Quick reply to this message
Old 09-11-2007, 09:55 AM   #4 (permalink)
View typesix's Photo Gallery
Believe that 2004 uses the ABS sensors for monitoring tire pressure by sensing rotational differences, not actual air pressure. If one tire is slightly different in size, it will set off the warning light. I had this problem with my 2004 Highlander after one tire needed replacing due to nail in sidewall.
typesix is offline   Reply With Quote Quick reply to this message
Old 09-11-2007, 02:41 PM   #5 (permalink)
typesix, just curious. I'm not familar with earlier TPMS. So if the system is based on tire rotational speed/differenes, does that mean the spare tire is not monitored (since it's not rotating)?
Old 09-11-2007, 09:57 PM   #6 (permalink)
wonger's Avatar
if your valve stems are rubber... and you have a tire pressure monitor system.. than its done thru ABS.. dont have to worry about the spare
if your vavle stems are made of metal.. than it has a direct link and knows how much pressures in each wheel.. includes spare ( unless you have a 07 tundra which only has 4 - none in spare)
again if the light is solid on.. than its just a difference in tire pressure... most have to be resetted after setting pressure
if the light is blink than one or more sensors is bad or theres a problem with the system 9 most if not all the time i see.. its been a sensor that was damaged) a toyota techstream or scan tool will tell you if one or more is bad
88 4Runner
Old 11-27-2007, 09:11 AM   #7 (permalink)
so is there a way to RESET the the sensor????
Old 11-27-2007, 11:03 PM   #8 (permalink)
wonger's Avatar
read my last post and tell me which ones u have.. and ill let u iknow how from that.. also is the light flashing or solid on>?
88 4Runner
Old 11-28-2007, 08:39 AM   #9 (permalink)
Talking
okay... yes the sensor light is on solid. How would one go about resetting it????? thanks in advance.
Old 11-29-2007, 01:38 AM   #10 (permalink)
wonger's Avatar
are your valve stems metal or rubber?
if they are rubber .. make sure all 4 tires are set evenly .. around 32-36psi
if they are metal .. make sure all 5 tires including spare are set evenly.. around 32-36
if u have an older rav4.. to the left of the steering wheel there should be a tall rectangular button that has like three dots below a line.. press and hold after tire psi set.. with key on.. and hold for like 20 secs
if u have a new rav4.. there should be a little round button somewhere under the steering wheel column or driverside lower dash area.. get down and look.. again with key on.. tire psi set.. press and hold for like 20 secs
also if u have metal value stems.. and no button can be found.. the light should turn of after driving like 2 feet.. or after like 15 secs after car is on and all 5 tire psi set evenly..
88 4Runner
Old 12-09-2007, 02:54 AM   #11 (permalink)
View githzerai's Photo Gallery
We had this problem and it turned out to be uneven tire pressures. I talked with a mechanic at Toyota and he said all tires must be within 6psi of eachouther or it will be lit. This includes the spare on ours, which kind of sucks cuz, we just got new tires where the new tires recommend 35psi and the factory spare recommends 28psi. Once we got the spare up in the 30's, the problem went away... just hope the added psi doesn't damage our spare
githzerai is offline   Reply With Quote Quick reply to this message
Old 12-09-2007, 01:08 PM   #12 (permalink)
wonger's Avatar
where you get the info that the new tires are recommended at 35psi? all recommended psi for all your tires are on your driver door jam near the vin sticker..
run more psi wont damage your spare
i always set most my tires to 34 to 36 psi..
alot of prius owners run even more for better mpg.. but in the long run the money you save in gas will cost you in tires cuz they will wear faster.. but this is for prius chat lol
88 4Runner
Old 12-09-2007, 01:41 PM   #13 (permalink)
We bought new tires from Les Schwab. (Sorry, coudn't afford the $1200 oem tires), so they are all different. Got the psi off the tire sidewall.
Old 12-10-2007, 12:56 AM   #14 (permalink)
View MacBandit's Photo Gallery
It doesn't matter what tires you put on there you should still start with the factory tire pressures. The tire pressure on the sidewalls is maximum tire pressure not recommended running pressure.
MacBandit is offline   Reply With Quote Quick reply to this message
Old 12-10-2007, 09:21 PM   #15 (permalink)
wonger's Avatar
spank you.. i just didnt know how to word it.. so i figure someone else would.. but the factory rec is aways best.. and not 10psi from the max of the tires you got which alot of old timers do
88 4Runner
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Tire Pressure sensors 05 Highlander GH05 1st Generation (2001-2007) 8 10-31-2007 08:08 PM
Tire pressure questions buckstom 2nd Generation (2007+) 6 09-02-2007 06:43 PM
tire pressure masteryota1 3rd & 4th Generation (1992–1996 & 1997–2001) 7 08-26-2007 06:48 PM
Odd tire pressure? newenglander 2nd Generation (2005+) 1 08-19-2007 08:28 PM
Tire Pressure, How much do you have? Chazmanian 2nd Generation (2005+) 28 12-07-2006 11:49 AM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
