Detonation is not about burning parts. Detonation is the igntion firing at the wrong time. The parts doesn't burn more than it normally does but the cylinders are fighting itself and putting excess pressure on the head, crank, cam, rods, pistons, etc.
Will the supercharger fit? It's not about the supercharger fitting but about the intake manifold fitting. If they use the same intake manifold yes it will fit (assuming you have clearance) You will need to run your own rubber bands to the engine. Throw in an air/fuel ratio controller and an ignition system that works with the Rav4 that can retard timing along with some gauges to keep everything in check and you'll be fine.
2004 Accord EX V6 Sedan - S2k retrofit, Koni Yellow, H&R, SPC, 2 10" JL, Brembo, Axxis Metal Master, AEM V2
2004 Vino 125 - Stock
2003 YZF-R6 - Power Commander, 2 Bros, fender elim, flush front, sliders
2007 Rav4 - Coming soon.
