Flashing Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
RAV4 Forum Looking for RAV4 information and resources? This forum is the place.
post #1 of 16 Old 05-30-2011, 10:11 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA Flashing Check Engine Light
I tried to do a serch for it but it says no matches. What does it means? I believe, by the way its running its the timing belt. Is there a thread here that describes the best way to change this and is there anything else I need to change while I am in there? Thanks for the help. I will post my findinds to help the next person.
I own a 1997 Rav4 with 160,000 miles on it.
Chazwel is offline
post #2 of 16 Old 05-30-2011, 10:20 PM
Super Moderator
heartdisease's Avatar
Quoted: 2384 Post(s)
Autozone will do a free code check IIRC. If it is flashing generally it means a knock sensor or something. I wouldn't drive it if I didn't know. Flashing means bad stuff and you could damage things!
heartdisease is offline
The Following User Says Thank You to heartdisease For This Useful Post:
Chazwel (05-31-2011)
post #3 of 16 Old 05-30-2011, 10:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you for the post. I can't believe the search tool for this website is so horrible. I will continue to search for some timing belt information, when I find it I will post here.
Chazwel is offline
post #4 of 16 Old 05-30-2011, 10:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Looks like you should replace the water pump also, as it is being run by the timing belt also. Here is a kit. Can anyone comment on the manufacture?
http://shop.advanceautoparts.com/web...010_1580225371____
Chazwel is offline
post #5 of 16 Old 05-30-2011, 11:00 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I know I am jumping on the timing belt being bad. I sounds if the engine is bogging down, so any other comments to steer me in a different direction is much appreciated. Thanks again.
Chazwel is offline
post #6 of 16 Old 05-31-2011, 06:49 AM
Quoted: 0 Post(s)
Do not drive it if light is flashing any more than you have to,like to auto parts store or repair guy to have code read.
What ever they say code says or means it does not mean you have to change parts it just shows area where trouble is. Most sensors can be checked with ohm meter and fuel pressure can also be checked.
Water pump and tensioner needs to be changed along with belt.
The biggest cost is labor getting to water pump and belt.
There is step by step here on timing belt and a lot more. www.rav4world.com
hd72m is offline
The Following User Says Thank You to hd72m For This Useful Post:
post #7 of 16 Old 05-31-2011, 08:26 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the info HD. I will post the codes I get from the auto parts store.
Mt. Airy? U know Steve Sobe?
Chazwel is offline
post #8 of 16 Old 05-31-2011, 08:45 PM
Quoted: 0 Post(s)
No do not know him.
hd72m is offline
post #9 of 16 Old 06-02-2011, 06:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Alright got some codes.........
P0446
Define- Evaporative emission control system vent control circuit fault.
Probable cause-
Open or short circuit condition
Poor electrical connection
Faulty CCV vent control solenoid
P0301
Define- cylinder 1 misfire detected
Probable Cause
Weak/missing spark
Plugged fuel injector
Engine mechanical fault
Large Vacuum leak specific to cylinder
That is all the codes. Does anyone know what they point to be the problem?
Thanks in Advance.
Chazwel is offline
post #10 of 16 Old 06-02-2011, 10:35 PM
Super Moderator
P0446
Probable cause-
P0301
Probable Cause
Weak/missing spark
Thanks in Advance.
Does your oil look milky? Bubbles in the radiator? I always worry about head gaskets. I don't know I might try a can of injector cleaner in every tank for awhile, Maybe throw a new set of plugs and wires on it, couldn't hurt with 160k for sure.
post #11 of 16 Old 06-03-2011, 09:05 AM
Quoted: 0 Post(s)
P0301
Timing belt would not throw this code
Rav4s have a lot of trouble with plug wires,do not use bosh wires!!!
Try timing light or spark checker for spark all the time.
If you pull the plug and look for spark it may do it for a little bit but still can be bad.
Also could be cap or rotor.
It also could be a valve or head gasket but look at above first.
P0446
Do you turn gas cap till it clicks 2-4 times and do you stop as SOON as pump stops?
These 2 thing are a must with newer cars.
All the system is is a vent on filler neck with check valve,hose to charcoal canister with a couple valves which feeds gas vapors back into intake.
If you pump gas after pump stops the charcoal can get too much gas and need replaced,around $200 or so...ouch,do not over fill.
Look at gas cap seal also.
Have heard many times with flashing light do NOT drive unless you really have to.
hd72m is offline
post #12 of 16 Old 06-03-2011, 08:32 PM
Super Moderator
Originally Posted by hd72m View Post
P0301
P0446
Every time I have ever gotten a evap code it doesn't flash, it is on steady, flashing is serious the evap is just incidental imho.
post #13 of 16 Old 06-04-2011, 02:34 AM
Quoted: 0 Post(s)
"Every time I have ever gotten a evap code it doesn't flash, it is on steady, flashing is serious the evap is just incidental imho."
heartdisease is right
hd72m is offline
post #14 of 16 Old 06-04-2011, 09:18 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I will be working on this today and will let everyone knolw the results. Thanks again.
Chazwel is offline
post #15 of 16 Old 06-05-2011, 08:56 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Bosh wires was the problem. The spark plug wire on the passenger side looked burnt. Thanks for all the help guys.
Chazwel is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > RAV4 Forum
User Tag List
Linear Mode Linear Mode
Back
