'97 rav4 power window problem
The driver's side window was operating erratically. Sometimes it would work, sometimes not, and sometimes it would work when you alternately pressed up and down on the switch a couple of times.
I guessed it was the switch, and not the motor. When I took out the master switch panel, all the other windows and power door locks stopped working.
I replaced the master switch panel with a used one, which the yard assured me was working when they pulled it (part is guaranteed), but still nothing works. I know its possible that the replacement is faulty, but I want to check other possibilities before returning the panel.
Can anyone please tell me where the fuse(s) or relays for the windows are? I've checked all five fuse boxes, but I don't see anything labeled for the windows.
Also, any other suggestions would be highly appreciated.
TIA,
JK
