98 Rav4 Starting Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > RAV4 Forum
RAV4 Forum Looking for RAV4 information and resources? This forum is the place.
Old 08-15-2005, 08:47 AM   #1 (permalink)
View Messiah's Photo Gallery
Hi everyone! My girlfriend has a 98 Rav4. It has a bit of a random problem when starting some times. The closest thing I can come to any sort of a patern is that it tends to happen more often after it rains or was just really humid out. The engine turns over just fine, and then the rpms drop and it sputters out and shuts off unless imediately put into gear and driven. It then proceeds to run fine after getting it up to 30 mph or so for about a quarter mile. If it stops before that, it tends to sputter out again and shut off.
It seems like it is having a fuel delivery problem of some sort to me. A garage thought it had to do with a temp/coolant sensor, and replaced it with no luck. They also say it could be an OS2 sensor.
Has any seen a problem like this, or have any advice.
Thanks.
Messiah is offline   Reply With Quote
Old 10-08-2005, 05:45 PM   #2 (permalink)
View RNeil's Photo Gallery
Trouble with rain or high humidity implies a high voltage ignition problem. Check the spark plug wires. Open the hood with the engine running in dim light. Look for sparks or corona on the spark plug wires or ignition coils.
RNeil is offline   Reply With Quote
Old 10-20-2005, 07:32 PM   #3 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
Clean out your throttle body inlet and IAC valve. They get clogged very easily. Common problem with 1st gen RAVs.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
