you would end up changing just about everything,toyota put oil cooled pistons,changed the compression,engine control computer,etc. so you would have to put in a supercharged engine as well if you wanted it to be as reliable as from the factory,several things would have to be changed around including the battery location,but yes if you have money you can do it,it would just cost quite a bit,not sure if it could be done on a 5speed probably if when you switched engines you put the 5speed flywheel on the supercharged engine,not sure if it'd work or not,the engine control might not standalone,but if you have money you can make anything work,lol,just my two cents
