engine/supercharger
you're totally right panda, the previas engine is totally unique and different from the mr2......just check out the long intake manifold on the previa's...its LONG...it somewhat aids in the air compression
btw, the supercharger on the mr2 is an eaton ROOTs SC12 and the previa's got an eaton roots SC14, and some differnt sized/ribbed magnetic clutch pulley... i forgot the displacement specs, but they numbers are significant...
mzar...just stick to the basic upgrades and you'll be fine... and if you do decide to customize your exhaust system to something less restrictive...lemme know how it turns out
