100amp fuse removal - Toyota Nation Forum : Toyota Car and Truck Forums
Previa Forum Discussion area for the (discontinued) Toyota Previa.
post #1 of 7 Old 07-09-2008, 05:23 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
100amp fuse removal
how do you remove the 100amp alt fuse in the box connected to the battery cable. 92 previa 2wd. Will not pull out, already cracked one side off
vtech is offline
post #2 of 7 Old 07-09-2008, 07:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
got it
vtech is offline
post #3 of 7 Old 07-09-2008, 07:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
does anyone know how much a replacement fuse box is? The one connected to the positive battery cable. I replaced the fuse and still have to giggle it around to get the van to start, i figure the box itself is worn out
vtech is offline
post #4 of 7 Old 01-07-2009, 01:00 PM
ptv
Quoted: 0 Post(s)
100amp alt fuse removal
How do you remove the 100amp alt fuse from the toyota previa van 92?
ptv is offline
post #5 of 7 Old 01-07-2015, 09:05 PM
Quoted: 1 Post(s)
How did you remove the 100 amp fuse from the fuse box on the battery cable???
bbreezydope671 is offline
post #6 of 7 Old 01-09-2015, 07:33 AM
Quoted: 0 Post(s)
It's bolted in place from the side. You need to remove the battery, and then you can get at the bolt.
tlhaas0000 is offline
post #7 of 7 Old 02-03-2015, 10:51 AM
Quoted: 0 Post(s)
It is bolted in place from both sides, mine has a 10mm bolt on one side and a 7mm on the other. Remove battery and bottom plastic cover and you can access them.
Matthew59 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Previa Forum
User Tag List
Linear Mode Linear Mode
Back
