1991 previa have a OBD or DLC port? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Previa Forum
Previa Forum Discussion area for the (discontinued) Toyota Previa.
Old 09-12-2012, 12:12 AM   #1 (permalink)
View 91n95previa's Photo Gallery
does a 1991 Previa have a OBD or DLC port, and if it does where is it located, i want to buy this scanner and hook it up to the car
http://dx.com/p/obdii-bluetooth-car-...e-dc-12v-42825
91n95previa is offline   Reply With Quote
Old 09-19-2012, 12:42 PM   #2 (permalink)
View keebler808's Photo Gallery
I am pretty sure your 1991 is the same as my 1995. So if you look under the front of the driver's seat, there is a little yellow latch that releases the seat to fold back for access to the engine compartment. Once you fold the seat back, the OBD receptacle should be clearly visible.
keebler808 is offline   Reply With Quote
Old 09-19-2012, 08:35 PM   #3 (permalink)
View tlhaas0000's Photo Gallery
Unfortunately, the Previa did not start to use the OBDII standard until 1995. I have a 1992, and it has the port under the seat, but it will NOT work with a OBDII scanner.
tlhaas0000 is offline   Reply With Quote
Old 09-20-2012, 12:18 AM   #4 (permalink)
The OBD2 was started in 1996. I have a 1995 and it's OBD1.
Old 09-20-2012, 05:18 PM   #5 (permalink)
View Robertino's Photo Gallery
I have a 95 and it's OBD1 and OBD2. Did you look under your fuse cover? that's where the OBD2 is hidden Yes it's true that OBD2 is from 96 and up , but Toyota was ahead of the game in 95 ...
Robertino is offline   Reply With Quote
