91 previa transmission problem
I hae a 91 Previa with uto and overdrive. Recently the transmission slips, or pops out of overdrive at soft throttle mostly on the highway, cruising along. Seems to happen when little load is on the engine/tranny.
Is there a solenoid or other electrical gremlin possibly, or should I begin looking for replacement? It slips (engine revs, car slows) for maybe 1 to 2 seconds, then back in and good for a while longer. Feels like a manual tranny if you depress clutch and immediately let it back out. It happens maybe once every fifty miles or so.
The tranny had full service (no power flush upon recommendation of tranny shop), about 2k miles ago. This issue began about 1k miles ago.
A related question, should the overdrive be turned off when ot in highway use?
Any help? Thanks! Greg
