Previa Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Previa Forum
Previa Forum Discussion area for the (discontinued) Toyota Previa.
Old 11-04-2004, 03:28 PM   #1 (permalink)
Old TN User
View heinz's Photo Gallery
Previa Problems
I have a 95 Previa DX and I have experienced a few problems of late. The first is that the radio will no longer recieve FM channels. The AM and tape deck work, but not the FM. The second is that the heater will only occasionally blow. I have tested the relays and the speed selector switch and all work. I do not know what else could be wrong.
heinz is offline   Reply With Quote
Old 11-04-2004, 03:51 PM   #2 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
Possibly your antenna isn't extended.. and your reception isn't picking up?
Check the vents, that's all i can think of. :\
Hope this helps.
troy is offline   Reply With Quote
Old 11-04-2004, 11:22 PM   #3 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Your heater fan has a resitor block on it that might be bad.
Here is a previa forum that is of great help.
http://groups.yahoo.com/group/previa/
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 11-05-2004, 05:21 PM   #4 (permalink)
View 400ex rocks's Photo Gallery
HI
I had the same problem. Guaranteed its the brushes in the blower motor. Most times you can take them out and replace or sometimes just clean them.
Rob
400ex rocks is offline   Reply With Quote
Old 12-09-2004, 02:45 PM   #5 (permalink)
ciw
1995 Previa SC
View ciw's Photo Gallery
I also have a 95 Previa and experienced the same problem with my radio. I figured it was time to replace it and put in one with a CD player. It took about 2 hours to install.
If you decide to put a new radio in be careful when remoing the cigarette lighter mouting bracket. The plastic is easy to break. You may want to get a wiring diagram to help with matching up the new radio wires or I believe you can buy a universal connector. Good luck.
ciw is offline   Reply With Quote
