93 previa interior lights don't work - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Previa Forum
Previa Forum Discussion area for the (discontinued) Toyota Previa.
Old 04-07-2005, 02:56 PM   #1 (permalink)
View Mr Tode's Photo Gallery
Hi,
our 93 previa's HVAC lights (all the heat/vent lights that should come on with the parking lights) quit working. Actually, it was intermittent for a while--could be coaxed back to life by running the vent selector through its range (!?). Now its dead completely. Fuse is good.
How do I get in there to inspect? What am I even looking for?
The second problem is the dome light in the rear, by the sliding door. That baby is dead too--bulb and fuse look OK there as well.
Any help is appreciated.
Mr Tode is offline   Reply With Quote
Old 04-09-2005, 06:33 AM   #2 (permalink)
View Skunkworks77's Photo Gallery
Pull out the fuse, clean it with a wire brush, then reinstall it. Or, put a new fuse. Sometimes, these fuses get tarnished on the connection points and won't conduct too good.
2001 Lexus ES 300 top of the line fully loaded.
1994 Toyota Camry with cleared lens and S2000 HID projector retrofit.
Skunkworks77 is offline   Reply With Quote
Old 04-15-2005, 12:07 PM   #3 (permalink)
View previa92le's Photo Gallery
For the sliding door light:
(1) Make sure the contacts are clean where the door contacts the forward part of the door opening. Use a pencil eraser to rub the contact surfaces.
(2) There's a "pin" switch covered by a black rubber boot located at the rear of the door opening. This has either (a) failed or (b) is not making good ground:
(a) You can take a ohmmeter and see if the switch has failed by placing one probe where the wire is attached (you need to remove the switch to access this stuff) and the other probe to a good ground point. Move the pin switch in/out and see if the continuity changes.
(b)Ground is through the mounting bolt so you may have to remove, clean, and reinstall.
previa92le is offline   Reply With Quote
