Previa Help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Previa Forum
Previa Forum Discussion area for the (discontinued) Toyota Previa.
Old 06-29-2005, 03:24 AM   #1 (permalink)
Terbo Guy
View black92celica's Photo Gallery
Previa Help
I'm working on a 94 Previa 2wd. I need to take off head because head gasket blew. Can the head be taken off withough while motor coming out? I'm new to the Previa. Where can I find info on doing the timing? Is it possible to do the timing chain and stuff while the motor is still in the car? And last, where can I find a list of the engine codes(what they stand for). Anyone know the codes or a page that shows them? I don't have a manual that's why I'm asking. I know they are probably in a manual or something. Help!!!
black92celica is offline   Reply With Quote
Old 06-29-2005, 08:25 PM   #2 (permalink)
View ARODYL's Photo Gallery
its easy to pull thishead off 1st get a manual, and remember always tie the camshaft sprocket to the timing chain, i use two wire ties and then the chain cannot move without turning the sprocket. be very careful!alot of this may not be clear at first, but this will save you time in the end! to replace the chain this job will become more difficult so if you dont have to then dont remove it!
ARODYL is offline   Reply With Quote
Old 06-26-2006, 08:01 PM   #3 (permalink)
View bradstep's Photo Gallery
Does the 92 Previa have a timing belt or chain? And when should it be replaced?
bradstep is offline   Reply With Quote
Old 06-28-2006, 10:24 AM   #4 (permalink)
Gameroom cash: $117630
View gideon1331's Photo Gallery
The Previa's all came equipped with chains...a good idea because of the mount position of the engine.
Some people will recommend changing the timing chain at a certain mileage, but unless you start having problems with the engine, you will probably never have to change it. My Dad has close to 200,000 miles on his 93 Previa with the origional chain.
Telltale signs of worn out timing chains are: Rough idle.
Sluggish performance and poor economy.
Sudden engine performance change including the inability to start the engine.
Intermittent backfire through the intake manifold.
Inconsistent ignition timing or a clattering noise coming from the front of the engine.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 07-09-2006, 03:11 PM   #5 (permalink)
View bluefever's Photo Gallery
yes the engine has to be completely removed in order to replace the head gasket,or atleast that's what my factory service and chiltons manuals tell me
bluefever is offline   Reply With Quote
