This may sound crazy but here goes. To access the plugs you need to remove the front passenger seat. I think there are 4 or 5 bolts holding it down. Once the seat is out remove the carpet where the seat you remove was located. Pull it back far enough to get access to the bolted panel. I think there may be 10 or 12 small bolts securing the panel to the body.
Once you remove the bolts the panel should slide out and you will see a bolted plastic cover. Remove the 3 bolts holding the cover and you will have access to the spark plugs.
Good Luck.
