Sequoia won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sequoia Forum
Sequoia Forum Discussion area for the large Sequoia SUV.
Old 11-06-2005, 10:13 PM   #1 (permalink)
View codypower's Photo Gallery
Sequoia won't start
I have a 2001 sequoia that is have an issue starting. Last week I tried to start it and it just cranked over. I let it sit for a couple of hours and it started right up. It has been running fine until today. It is doing the same thing. Here is what I know.
Sounded like it was not getting fuel or Fire
1. Checked fuel cap. No Vacuum lock.
2. Pulled # 1 plug has Fire plug is dry.
I believe that it is a fuel problem, where is the best place to pull a fuel line to check the flow of gas?
Where is the fuel pump?
Any other suggestions would be great.
Thanks,
Rick
codypower is offline   Reply With Quote
Old 01-27-2006, 12:58 PM   #2 (permalink)
View ephilyawjr's Photo Gallery
Key Problem
Where do you keep your keys?
If you keep your Sequoia Keys near another set of keys, it can cause your car not to start. The keys have a magnetic discharge that the security system reads when you try to crank the car. If your magnet has been interferred by being close to another magnet (Other keys) your car will not start by the security system shutting down the fuel line. I have set my Sequoia keys next to my 05 Nissan Titan keys, and nether vehicle will crank for like 30 minutes.
The dealership are clueless to this knowledge, Well actually Ford has a TSB on this issue. The dealerships can't diagnose the problem, beacuse it is fixed when they get it.
Think back and remember if your keys were near another set at the time (like in your pocket)
ephilyawjr is offline   Reply With Quote
