2002 key program instructions:
1.. Copy the cuts of the original working key onto the appropriate
transponder blank.
2.. Enter the car and close all of the doors.
3.. Simultaneously depress and release both the brake and accelerator pedals.
4.. Within five seconds, insert a working pre-programmed key into the ignition cylinder, and turn to the "on" position.
5.. Within fifteen seconds of turning the ignition, depress and release
the accelerator pedal five times for a primary key. (Depress and release four times for a valet key.)
6.. Within twenty seconds, depress and release the brake pedal six times for a primary key. (Depress and release only times for a valet key.)
7.. Turn the ignition to the "off" position and immediately remove the
key.
8.. Within ten seconds of removing the key, insert the new key and turn it to the "on" position.
9.. Within ten seconds, depress and release the accelerator pedal once. The security light will then flash for 60 seconds and then turn off. When the security light stops flashing the programming should be complete.
10.. Start the vehicle to verify that programming was successful.
For programming the keyless remote - you can email me and I can send you the pdf file:
LVAUGHNR@yahoo.com
