2008 sequoia wiring diagrams - Toyota Nation Forum : Toyota Car and Truck Forums
Sequoia Forum Discussion area for the large Sequoia SUV.
post #1 of 8 Old 08-01-2008, 12:47 AM Thread Starter
BO
Quoted: 0 Post(s)
(Thread Starter)
does anyone have or know where i can get the wiring diagrams for a 2008 toyota sequoia?
big_bo is offline
post #2 of 8 Old 08-01-2008, 05:13 PM
devo's Avatar
Quoted: 0 Post(s)
ebay?
devo is offline
post #3 of 8 Old 08-03-2008, 06:32 PM
Quoted: 0 Post(s)
$10 for one day usage.
https://techinfo.toyota.com/techInfo....toyota.com%2F
You probably have to d/l their viewer and stuff but its worth it. This is wut the dealership uses but they have a permanent account of course.
ScareyH22A is offline
post #4 of 8 Old 11-11-2008, 10:13 AM
2001 Sequoia Limited
jd50i's Avatar
Quoted: 0 Post(s)
I am not sure what you are trying to do IE; troubleshoot or install something but here is a partial;
MODEL YEAR(S)
SEQUOIA 2008 -
KEY T-HARNESS IMMOBILIZER
N/A N/A Transponder Anti-theft requires 791 and extra ignition key (SOME MODELS)
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE AND BLUE (+) IGNITION SWITCH HARNESS
STARTER GREEN (+) IGNITION SWITCH HARNESS
STARTER 2 N/A N/A
IGNITION 1 LIGHT GREEN (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK (+) IGNITION SWITCH HARNESS
IGNITION 3 N/A N/A
ACCESSORY/HEATER BLOWER 1 GRAY (+) IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A N/A
KEYSENSE GRAY (-) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - ) ORANGE (-) AT VEHICLE LIGHT SWITCH
PARKING LIGHTS ( + ) GREEN (+) IN PASSENGER KICK PANEL
POWER LOCK RED(-)TYPE B AT BCM MODULE BEHIND DRIVERS SIDE OF DASH
POWER UNLOCK WHITE(-)TYPE B AT BCM MODULE BEHIND DRIVERS SIDE OF DASH
LOCK MOTOR WIRE
DOOR TRIGGER BLUE (-) AT VEHICLES DIMMER SWITCH
DOMELIGHT SUPERVISION USE DOOR TRIGGER
TRUNK RELEASE N/A N/A
SLIDING POWER DOOR N/A N/A
HORN ORANGE (-) AT STEERING COLUMN HARNESS
TACH BLACK/YELLOW AT ECM MODULE ON PASSENGER SIDE OF FIREWALL
WAIT TO START LIGHT N/A N/A
BRAKE ORANGE (+) AT SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM USE KEY SENSE WIRE IGNITION SWITCH HARNESS
ANTI-THEFT TRANSPONDER ANTI-THEFT TRANSPONDER @ IGNITION SWITCH TUMBLER
jd50i is offline
post #5 of 8 Old 11-12-2008, 09:02 PM Thread Starter
BO
Quoted: 0 Post(s)
(Thread Starter)
thanks
thanks for the info scary and jd very insightful
big_bo is offline
post #6 of 8 Old 03-19-2009, 04:27 PM
Quoted: 0 Post(s)
Can you help me w/ the whole JBL wiring diagram for a 2008 toyota sequoia?
PokyTech is offline
post #7 of 8 Old 03-20-2009, 09:17 AM
jd50i's Avatar
Quoted: 0 Post(s)
USA
Unfortunately I am currently in Afghanistan and I am not able to check for this information. Sorry. I won't be home until April.
jd50i is offline
post #8 of 8 Old 04-03-2016, 10:03 PM
Quoted: 0 Post(s)
navigation, Radio and Outside rear view mirror
2008 Sequioa - Navigation, Radio and outside rear view mirror control lost all power. I tested the fuses and one of the 7.5 amp fuses blew. I replaced and everything worked again for a week. Now everything has no power again. Replaced the fuses again and still nothing. Any suggestions?
bdonovan1 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sequoia Forum
User Tag List
Linear Mode Linear Mode
Back
