Replace two catalytic convertors? Codes P0420B and P0430 - Toyota Nation Forum : Toyota Car and Truck Forums
Sequoia Forum Discussion area for the large Sequoia SUV.
post #1 of 9 Old 11-14-2010, 08:25 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Cool Replace two catalytic convertors? Codes P0420B and P0430
I own a 2002 Sequoia with 127K miles on it. Two years ago, I had one of the catalytic converters replaced with an aftermarket one (due to an emissions test failure which indicated that this was the issue). Now, I am attempting another emissions test, and the codes being provided by the shop are P0420B and P0430. I was quoted over $3,700 to replace both of them with Toyota OEM parts, which is highly recommended by this shop (they say due to frequent failure of aftermarket converters). In any case, I've had to park the vehicle while I attempt to save up the necessary amount.
My questions: should I trust the codes here, or could there be a faulty oxygen sensor which is triggering the codes (even though the sensors indicate that they're indeed working ok)? Further, do you agree / highly recommend that I replace these catalytic converters with OEM parts? My wife still likes the vehicle, and we've decided to repair it and move forward. One more thing, if OEM parts are the order of the day, do you have a recommendation as to where I might order them at a discount?
Thanks very much in advance for your insight / advice on this!
wovedog is offline
post #2 of 9 Old 11-15-2010, 10:03 AM
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Quoted: 5 Post(s)
iTrader Score: 13 reviews
I am going to send you a PM for some information. But as far as OEM parts goes, I sell to TN members for 30% off MSRP and I only charge actual shipping costs plus $1.00 - $2.00 for materials.
In my opinion, I frequently see how someone trying to save money comes back to haunt them later. With that being said, when you did the aftermarket pipes, did you replace the Oxegen sensors then? You have a total of 4 sensors on this vehicle, so anything is possible. Before I went the replace two new pipes, I'd chech and eliminate everything first. If you trust this shop and you take it to them regularly, chances are they are on the up and up, if not, I'd seek a second opinion.
Gary Smith-Parts Manager
TOYOPARTSMAN is offline
The Following User Says Thank You to TOYOPARTSMAN For This Useful Post:
wovedog (11-16-2010)
post #3 of 9 Old 11-16-2010, 08:50 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks much, TOYOPARTSMAN! To my knowledge, the sensors weren't replaced when I had the aftermarket cat installed two years ago. Yes, I trust my current shop, but they aren't really creative solutions-oriented - they simply provided me the codes and said that the cats needed replacing (per what the codes indicated).
Would it make any sense for me to simply replace all four sensors, reset the check engine light, and then see what happens? Or, should I take it to a dealer to have them run the steps that are contained in the pdf that you sent me via PM? I am fairly handy (comfortable with performing oil changes, brake pad replacement, etc.), so is changing the sensors something that I should tackle myself?
Thanks again for your insight and advice!
wovedog is offline
post #4 of 9 Old 11-16-2010, 04:19 PM
Quoted: 5 Post(s)
Thanks much, TOYOPARTSMAN! To my knowledge, the sensors weren't replaced when I had the aftermarket cat installed two years ago. Yes, I trust my current shop, but they aren't really creative solutions-oriented - they simply provided me the codes and said that the cats needed replacing (per what the codes indicated). From what I read, you check the sensors first.
Would it make any sense for me to simply replace all four sensors, reset the check engine light, and then see what happens? Here is the gamble if you go that route. We had a car in our shop just last week, a highlander, where 3 fo the 4 sensors were bad. Other than that vehicle, I have never seen where a vehicle needed all four sensor at one time. Now, in your situation, I am not sure if that wasn't needed two years ago or not. Or, should I take it to a dealer to have them run the steps that are contained in the pdf that you sent me via PM? You could, but I suspect they would tell you the same thing I would, we have to put OEM Cats back on before we could test the system. This is the area where a Dealer cannot properly diagnose a car because it may or may not be up to Specifications. We don't have the abilty to test and check other manufacturers equipment and parts. I am fairly handy (comfortable with performing oil changes, brake pad replacement, etc.), so is changing the sensors something that I should tackle myself? The only thing I see as a problem here is that I have seen those sensors get stuck and even experienced techs have had trouble. If you go this route, spray and let the sensors soak using PB blaster. Since these were replaced two years ago, you shouldn't have to much trouble.
Professionally, I'd love to sell you two new CATs, but personally before I did that I'd suggest you try the most economical and less expensive route. IF IT WERE ME AND MY CAR(I wouldn't have used aftermarket CATs, sorry) I'D TRY THE FRONT TWO SENSORS FIRST. RESET THE SYSTEM, AND IF IT FAILS, TRY THE TWO REARS. THEN PROCEED TO THE CATs.
As for the sensors, you can get them from me, but I have heard other members use aftermarket, either Bosch or Nippondenso. Nippondenso is the manufacturer for Toyota. But, and I emphasize BUT, you are having a repeating problem with this issue. I would seriously suggest spending the extra money and get OEM ones. Whether you buy them from me or not, at least this way you know that you have OEM sensors. If it doesn't solve your problem and you end up having to replace the CATS with OEM, you can at least transfer the OEM ones to the new CAts.
I'll give you my reasoning with this direction. 4 sensors total will run you a lot less than two new CATs. Just because you replace two new CATs doesn't mean that a sensor isn't bad in there too. 2002 Sequoia, sensors are about due, at least I am playing the odds. Unless you put new sensors in, that is a reasonable assumption. Under my thought, you have at least done a process of elimination with parts that you can use and transfer if it doesn't solve the problem. The only down side, is monetarily where you will always wonder if you had spent more money than needed.
Let me know if this makes sense to you, and if you have any questions, want to run an idea by me, need more information, or think I am off my rocker PLEASE feel free to contact me. I don't mind running all the different scenario's down with you, etc, and if you think I'm crazy I won't be offended. My only desire here is for you to get you car fixed, and fixed properly, with the least amount of expense and headache possible.
03CamryLEV6 (06-08-2012)
post #5 of 9 Old 11-16-2010, 09:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
All makes sense to me, TOYOPARTSMAN. I'll send you a PM to talk about the particulars, but I plan to proceed with replacing the front two sensors, and I'll update the forum here with the results.
Thanks!
wovedog is offline
post #6 of 9 Old 12-29-2010, 03:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Smile
Well, just to update the forum, I ended up purchasing two OEM catalytic converters and had them installed. TOYOPARTSMAN talked with a master tech, and we decided that this code definitively indicated replacement of the CATs was necessary and appropriate.
Check engine light has stayed off, and the vehicle passed state emissions test, so we are back on the road.
My thanks to this forum, and especially to TOYOPARTSMAN for his insight and assistance with this!
Happy New Year!
wovedog is offline
The Following User Says Thank You to wovedog For This Useful Post:
TOYOPARTSMAN (12-30-2010)
post #7 of 9 Old 01-03-2011, 12:51 AM
Quoted: 0 Post(s)
I had the same code numbers described here, replaced all four O2 sensors on '01 Sequoia about six months ago and codes had not come back.
kintosol is offline
post #8 of 9 Old 01-07-2011, 10:18 AM
Vote for me! Toyota.ca!
T100Supra's Avatar
Quoted: 0 Post(s)
Ya we just had our cat go on our 2003
It sucks but ya OEM is the way to go... payed alot for it but its got the best warranty
Plus it fits better and sounds alot quieter than it did
Not sure about the codes... I can look them up one day but ya they had ours on the computer and the cat was dead
We had to reset our computer too as it was some recall thing
Anyway lights came on our dash and was messed up
Abs, traction, another traction, check engine
Ya go to dealer is the best choice, they know what they are talking about
Ohh ya and use premium gas! We have always but I guess the old owners didn't so it was bad for the CAT. The dealer asked us straight out if we use the better gas, makes them last longer, but again you pay for it. If we didn't after like a year of owning it we wouldn't have gotten away with it for so long. It probably was ready to go when we first bought it =( .Both our old beasts only get the finest... either 91 or 94 octane, same with sequoia. Full synthetic AMS oil or quaker only used... Toyota's last but you gotta give them the proper fluids
1995 T100 Extended Cab 4x4 SR5 Auto- Back Rack and TRD Off Road Stickers, almost 400km's
1996 4runner Limited 4x4
2003 Sequoia Limited 4x4
1982 Celica Supra hopefully some day
T100Supra is offline
post #9 of 9 Old 05-14-2012, 07:37 AM
Quoted: 0 Post(s)
I had P0430 at 178k in my '01 Sequoia. Replaced front sensor and code returned, then replaced rear sensor and code has stayed away. From reading diagnostic theory on P0420/P0430, the O2 sensors must be performing optimally or the code will show up...of course, it could be a bad cat as well, but I'd much rather replace two O2 sensors for $110 before replacing an $800 cat.
makatak62 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sequoia Forum
Tags
catalytic , converter , oxygen , sensor , sequoia
User Tag List
Linear Mode Linear Mode
Back
