C. wrote:
> When I used the term "Sidewall" I am refering to the sidewall of the tire.
> You can change tires and that tire may have a different pressure rtating
> than the tires that came on the car from the factory.
> Remember Ford Explorer and their tire problems? Underinflated tires can
> heat up excessivly.
> go this website and read the first paragraph about tire pressure
> http://www.rvadvice.com/rvarticles/4tires.html
> C.
> In article <wXCde.6519$iU.1717@lakeread05>, "harry" <harry_liu@lcc.com> wrote:
>>The "sidewall" label says 32 PSI.
>>My question is who do I follow? I imagine that 32 PSI was posted by Toyota
>>based on the tire they put on the new car. What if I change to other brand
>>name/type of tires? That new tire may have different pressure suggestion.
>>The label is no longer useful in that situation...?
Just my 2 cents (I'm not a tech, just an enthusiast). None of my
comments are meant to be argumentative...
Sidewall numbers are only max pressure when the tires are cold. The
vehicle oem tire pressure specs should be for an empty vehicle (well,
add a driver and a single passenger). If you were hauling a load of
bricks, then 1. you shouldn't exceed total hauling capacity, and 2.
raise rear tire pressure to max tire rating (sidewall number).
I'm preaching starting with vehicle mfg tire pressure specs, which also
means when replacing tires to not use load ratings that are lower than
factory ratings - you could, but you would be on your own for doing the
math on tire pressure and carrying capacities.
Based on the assumption the original poster mentions different sized
tires, I'm assuming he's talking a slight difference and he's not
running either extreme of ultra low profile (lowered vehicle) or super
balloon tires on a lifted truck.
IMHO Ford's choice with the Exploder (Explorer) to use lower tire
pressures to make the truck ride smoother (car like) was a major goof.
It was just cheaper than re-engineering the chassis. And the general
public continues to drive SUV's and pickups like cars - they don't seem
to understand the difference in the characteristics of cars and trucks.
Trucks (and I still refer to SUV's as trucks) are bricks with wheels -
they don't accelerate, turn or stop like a car.
You probably see as many examples of poor driving in your area as I do -
in the first few years of the SUV craze I lost count of how many of them
I saw on their roof's because of driver error.
