"harry" <harry_liu@lcc.com> sez:
<snip>
> Time to change my original tires on Sequoia 2004 Limited.
The OEM skins are lame, I pulled 'em right from the start off the missus'
Sequoia and off my Tundra D-Cab, sold 'em through the paper to recoup a few
$$$s and put decent rubber on. Being the last line of defense on the road,
I want all the advantage I can get. :-)
> Read a lot of good responses on The Michelin CT or LTX M/S. Unfortunately
> the LTX does not have the right size for Sequoia 265/65/R17 while CT seems
> to have it.
I'm running the 265/70/R17 on the Sequoia & Tundra without any interference
problems and the LTX M/S comes in that size. See:
http://www.tirerack.com/tires/Sizes....odel=LTX+M%2FS
> Though Michelin rates CT and LTX same tread life, the response
> on Forum does not seem that way. LTX is definitely winning on votes in
> terms of tread life. I really hope not to change tires again in 40,000
> miles.
The LTX M/S tires I run on the Tundra, 265/76/R16 LR-E for running
loaded/towing (I have both 16 & 17" rims so have two sets of tires), already
have about 30,000 miles on them and given the amount of tread left they'll
deliver between 60-80,000 mi. total. While a nice long-life tire with quiet
road manners, they leave a little to be desired in the wet and even more to
be desired in the snow.
> What other choices do I have?
Seriously consider the Bridgestone Dueler A/T Revos:
http://www.tirerack.com/tires/tires....ler+A%2FT+Revo
They are excellent tires, very quiet at speed and have much better wet/snow
traction than the LTXs. They likely won't deliver the 60,000+ miles that
the Michelins will, but they'll give you the 40,000+ you are looking for and
probably over 50,000 unless you drive more aggressively.
Check out the survey results at:
http://www.tirerack.com/tires/survey....jsp?type=ORAT
My experience with both the LTX M/S and the A/T Revo are spot on with what
the survey reflects.
Good traction to ya,
VLJ
