Shifting out of park - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 01-02-2006, 05:42 PM   #1 (permalink)
View tsmac2's Photo Gallery
Shifting out of park was noticably resistant over the last few weeks but today, its very difficult. I can force it out of park and then shifting between the other gears is easy but as soon as I put it back in park it again does not want to shift out. If I push the override button just above the shifter with a screwdriver it agains move out of park. I also noticed that my brake lights don't come on when I push the brake so I checked the fuse and it was blown. I changed out the fuse and it blew again. I took the brake switch light out and replaced the fuse. Its not blowing at this time. I attempted to bypass the switch by connecting terminals 1 and 3 of the brake switch connector but the lights didn't come on. Not sure if I did it right or used the right kind of wire.
Any ideas or suggestions?
tsmac2
tsmac2 is offline   Reply With Quote
Old 01-10-2006, 11:01 PM   #2 (permalink)
Smile Shifting out of park (update)
Well, I checked out the brake light switch for continuity on an ohm tester and it was fine. I found a decsion tree in the Toyota Lancruiser repair manual and given my symptoms, it indicated that there was likely a short between the brake light switch and the lights. At that point I took it into the dealer and they found that the trailer harness was bad (corroded) and was causing fuses to blow which prevented the car from being shifted out of park.
Shifting from park witxp Camry & Solara Lounge 13 07-03-2005 12:02 AM
Shifter "Locked" in Park Wannago Tercel, Paseo, Starlet, and Sera Forum 1 06-14-2005 06:37 PM
Hard to move from Park to Reverse fruto123 Camry & Solara Lounge 13 07-12-2004 09:02 PM
Problem shifting out of park!! DscCamry97 Camry & Solara Lounge 2 09-23-2002 01:39 PM
