door lock problem on Land Cruiser - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 02-27-2006, 11:29 AM   #1 (permalink)
View johnbadman's Photo Gallery
Hope somebody can help,
Have a 97 Lancdcruiser with a strange problem. Once door locks are engaged every right turn the locks unlock, the dome light goes on and the door open icon on dash lights up. This is only for right hand turns. All othe r driving is fine. Dealer and mechanic have no clue and think diagnostic will cost a fortune.
Anybody with a cruiser have this problem or know what could be causing it ?
Thanks for your help,
john
johnbadman is offline   Reply With Quote
Old 07-15-2006, 11:50 AM   #2 (permalink)
View kasmus's Photo Gallery
same problem
I have a 97 LC and it does the same thing but on bumpy roads. I suspect the driver's door switch is faulty but don't have time to pursue it. Any idea?
kasmus is offline   Reply With Quote
Old 07-15-2006, 05:51 PM   #3 (permalink)
View toyomoho's Photo Gallery
My guess is one of the door switches or wiring to a door switch has a problem. If one of these switches opens, or a wire disconnects. The door locks may open; the dome light goes on along with the door open light. Do all the door locks unlock when any door is opened, or only just the driver’s side? If just the drivers side, start there.
A right turn would seem to cause the drivers side doors to move outward a little. I would check these doors first. Try putting some type of spacer between the door and switch to force the button on the switch more inward. Then take a test ride.
Old 07-21-2006, 08:24 AM   #4 (permalink)
That's the problem indeed
I bought my '97 LC used and the previous owner had the rubber boot/switch on the driver's door taped down hard, and there was no problem. So of course I took off the tape so that the dome light would come on at night when I opened the door. Then, turning right or on bumpy roads, (lots of those here in Ethiopia), the dome light came on and the doors all unlocked.
I suspected that it was the door switch, and looked up the problem on Google, found this query.The door itself just doesn't press the detent switch in far enough, and the door wiggle when driving is enough to make the switch disengage. I pressed against the door with my elbow from the inside and as expected the doors unlocked and dome light came on.
The fix: I cut about a 1/4 inch off a wine bottle cork and taped it to the door where it presses against the boot, and it worked fine after that.
--K
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 10:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 11:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 02:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 11:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 02:33 PM
