P0135 O2 Sensor Heater Circuit Malfunction - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 04-25-2007, 03:26 AM   #1 (permalink)
View icek1's Photo Gallery
Question P0135 O2 Sensor Heater Circuit Malfunction
I have a 2000 model LC, it came up with the check engine light and traction and skid control off.
After running a scan on the LC I got the following error codes:
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
Does anyone know how to fix these?
The P0135 error code came on first, then followed by P0121 and P0155 after about 35miles.
Any help will be appreciated.
icek1 is offline   Reply With Quote
Old 08-09-2008, 07:59 AM   #2 (permalink)
View stagescott's Photo Gallery
I just got the same p0135 error...what did you do????
stagescott is offline   Reply With Quote
Old 08-09-2008, 11:43 AM   #3 (permalink)
View toyomoho's Photo Gallery
The code is related to the sensor outlined in the post above yours.
Bank 1, Sensor 1 is the cylinder head nearest the firewall, Sensor 1 is the first sensor on the exhaust manifold (exhaust system).
Old 10-28-2008, 12:16 AM   #4 (permalink)
View SCoupe's Photo Gallery
New oem o2 sensor, same code
I am now on my third freakin sensor to solve the CEL PO0135 code. First I used a universal o2 sensor, that did not fix it, so I just drove the truck for a year anyway. I then bit the bullet and purchased a brand new Toyota OEM sensor and I am still getting the PO0135 Code, o2 sensor Heater Circuit Malfunction (Bank 1 Sensor 1).
Does anyone have any idea what is going on here?
2000 Tundra v-8 engine 86,000 miles
SCoupe is offline   Reply With Quote
Old 10-28-2008, 12:26 AM   #5 (permalink)
just a nobody
Which sensor did you replace?
N.E.O.
Old 10-28-2008, 12:31 AM   #6 (permalink)
Passenger side, pre-cat, near the exhaust manifold with the bonus total PITA connection plug way too high on the auto tranny housing.
Old 10-28-2008, 12:32 AM   #7 (permalink)
just a nobody
That is Bank 2 sensor 1, Bank 1 is the left bank.
N.E.O.
Old 10-28-2008, 12:40 AM   #8 (permalink)
That then would be the best news I could hope for. I will swape the old one to the other side. Thankfully I still have the good one that I incorrectly pulled. If this proves out I will have to acknowledge that I am a pitifully uninformed weekend mechanic and that I wasted an enormous amount of time, energy an money on failed replacement of a perfectly good part, wasted money on two smog checks and more time than I want to admit. I am pissed, but I do thank you for pointing me to the other side of the truck.
EDIT: Huge and proper recognition to member "new echo owner". The advice was bullseye accurate and the freaking CEL issue that has vexed me for ~2yrs was solved in 10 minutes. I was doing the right thing on the wrong side of the engine. The sensor on the Bank 2 is quick and easy using the proper tool (o2 sensor socket). The harness disconnect is quick and easy. Thanks again !
Old 10-28-2008, 12:51 AM   #9 (permalink)
just a nobody
Toyota did pull one on a lot of people, on the V6 Bank 1 is the right side; when they went to the V8 they had switched it around.
N.E.O.
Old 08-17-2009, 12:21 PM   #10 (permalink)
View RickC's Photo Gallery
Where does one get the part and does anyone have any pics of what I am looking for. I too am getting the p0135 error code.
I have done this on a 4runner in the past, but it's different sensor design I think because it could just be cleaned with electronics cleaner.
Thx,
RickC
RickC is offline   Reply With Quote
Old 06-28-2011, 04:27 AM   #11 (permalink)
View Kiddan's Photo Gallery
the engeen error light shows and P0135 O2 sensor Bank1 is the error code. My car is Toyota Avansis with engeen 1ZZ-FE - Denso -MT.
Can any one tell me how to fix this error?
Kiddan is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
