Headlight Dimmer Switch Keeps Blowing-Help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 01-10-2008, 06:14 PM   #1 (permalink)
View beemin3's Photo Gallery
USA Headlight Dimmer Switch Keeps Blowing-Help
I have a problem with my 86 FJ60.
When I turn on the headlights, the headlight control relay buzzes and the headlights won't come on.
Running, turn, hazzard lights and switches work.
I tracked it down to the dimmer switch. Swapped it out with one from the Pick and Pull from an old Corolla (no LCs in the junk yard, no surprise). It fit perfect, connected the wires and everything worked, until....a couple days later.
I went to drive home from work and it happened again. I know what is broke (headlight dimmer switch), but have no clue what is causing it to blow.
Pls help!!
Last edited by beemin3; 01-10-2008 at 08:15 PM. Reason: I'm new, thought it would show yr/model of my LC
beemin3 is offline   Reply With Quote
Old 01-14-2008, 09:05 PM   #2 (permalink)
Dimmer Switch--not
Seems to be an intermittent ground fault. Jumping seems to keep the headlights on.
So, you want to know when your fogs are on? slvrAZtaco 2nd Generation (2005+) 71 09-04-2011 05:40 PM
DIY Modification Articles for the 95-04 Tacoma cam2Xrunner 1st Generation (1995.5–2004) 12 01-21-2010 09:05 AM
2003 Camry Headlight switch deltagundam 5th & 6th Generation (2002-2006 & 2007-2011) 9 03-26-2007 11:09 AM
Hella 500 light switch ? Mike-in-WV 1st Generation (1995.5–2004) 3 12-28-2006 07:33 AM
headlight switch doinou Pre-88 Toyota Pickup/Hilux 0 11-19-2006 11:40 PM
