Landcruiser Spark Plug Location - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 06-18-2009, 08:33 PM   #1 (permalink)
kde
View kde's Photo Gallery
Does anyone have pictures that show where the spark plugs are located on a 2000 Landcruiser?
My engine turns over, but does not start. Looking to replace the spark plugs (it's been awhile since they were last replaced).
kde is offline   Reply With Quote
Old 07-07-2009, 11:07 PM   #2 (permalink)
View greencamry's Photo Gallery
Is it a 6 cylinder 1FZFE motor? If so they are in the head cover where the spark plug wires enter on top. Remove the spark plug wire with it's cover. Do not pull the wire, grip the cap and pull it out, then the plug is down inside the cover. If it is a 3FE motor they are visible in the side of the head. If it is a 1HZ or 1HDT Diesel motor they do not have any. cheers
greencamry is offline   Reply With Quote
Old 03-03-2011, 10:09 PM   #3 (permalink)
View parkertl's Photo Gallery
did you ever figure out what the issue was?
I have a 99 land cruiser and today I experienced where the engine would turn over but it wouldnt start on the first couple of tries. (it acts like an old car or truck that you have to pump the gas pedal to get it started) Ive never had an issue before and the car started fine prior to today.
thanks
parkertl is offline   Reply With Quote
Old 03-09-2011, 02:13 PM   #4 (permalink)
View 2000UZJ's Photo Gallery
100's have a problem with fuel flooding after very short drives. If it happens again floor the truck while turning it over. Happens to me while wheeling, you will notice when you move it in the driveway, shut it off and turn it back on. It will sputter to life. I let mine run for a couple minutes if I just need to move it.
2000 Toyota Landcruiser - Built and Abused
Landcruiser Forum
2000UZJ is offline   Reply With Quote
