2000 Land Cruiser Transmission Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 09-24-2009, 11:54 PM   #1 (permalink)
View LC100's Photo Gallery
Hi,
I just had to replace the transmission in my 2000 Toyota Land Cruiser. It only had 108k miles on it. I was on a road trip when it started shifting funny. When I pulled over and went to put it in any gear, it would kill the engine. It was acting like a manual transmission does when you fail to clutch it at a stop or slow down. I had to have it towed. The Toyota dealership told me I needed a new transmission at the tune of $3,250! Ouch! Has anyone else had this happen to them? I have owned dozens of Toyota's and have never had a problem with a transmission... this really surprised me. Is there a known problem with these transmissions?
Thanks,
LC100
LC100 is offline   Reply With Quote
Old 09-25-2009, 04:16 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $548155
View fourwd1's Photo Gallery
I'd find an independant trans shop with a good rep (there are some) but NOT a chain shop like AAMCO or Cottman, and talk to them. It could be something simpler/cheaper, like a bad torque converter or solenoid. It could be worth towing to them to look at. But I'd defenitely get a second opinion.
Were there any error codes stored in the ECM that might give a clue?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-26-2009, 01:09 AM   #3 (permalink)
Unfortunately I was on the Oregon Coast on a road/camping trip with my family and I did not know of anyone in the area that worked on transmissions. Even the tow truck driver said that taking it to the nearest dealer was my best bet because there were a lot of "hokey" mechanics in the area. The dealer did not mention any error codes. I just have a tough time with the fact that a Toyota transmission went out at 108K miles. Especially in a vehicle like the Land Cruiser that you pay top dollar for. Has anyone else with a 100 series Land Cruiser shared this unfortunate fate?
Thanks,
LC100
Old 09-30-2009, 07:31 PM   #4 (permalink)
View 2000UZJ's Photo Gallery
Your not the only one.
In 2000 Toyota switched Who made their trannys. Unfortunatley a few parts were swapped and were prone to fail early. Some at 25K under warranty. And some at 200+ out of warranty. When Toyota discovered it they switched back to araco ( I believe). 2000 was the only year of the big tranny issues. Other years pop up every now and then. Also the cracked exhaust manifolds were prone in 2000 due to a lack of engineering and quality. I have 1 cracked manifold ( to to cold water crossing on hot engine ). There isn't really a fix for either besides replacing them. Some have had luck welding some haven't.
As for the tranns issue. Your not alone, join www.ih8mud.com and you can post there. People other there will be much more knowledgeble that here.
Nick
2000uzj
2000 Toyota Landcruiser - Built and Abused
Landcruiser Forum
2000UZJ is offline   Reply With Quote
Old 09-30-2009, 10:10 PM   #5 (permalink)
Nick
2000uzj
Old 09-30-2009, 10:16 PM   #6 (permalink)
Nick,
Thanks for the knowledge! That explains a lot! I ended up having Toyota put a re-manufactured Toyota transmission in. Do you know if this would have the same "poor" parts in it?
Thanks,
Nate
LC100
Old 09-30-2009, 10:24 PM   #7 (permalink)
Nate,
if it is a re-manufactured I would think the tranny would be pre-2000 (98-99) or a 01-02. 03+ were fitted with a new 5 speed. So your tranny probably is probably a 98-02. The guys on MUD who have had failed trannys can help you more indepth as I know the basic knowledge.
I would think Toyota would be smart enough to "discard" the trannys with the failed parts.
Landcruiser Forum
Old 09-30-2009, 10:29 PM   #8 (permalink)
Nate,
Old 09-30-2009, 10:31 PM   #9 (permalink)
Nick,
Thanks again. I would think that they probably "discarded" them too. I will go and sign up on Mud. Sounds like a knowledgeable group!
Thanks!
Nate
LC100
Old 09-30-2009, 10:35 PM   #10 (permalink)
That it is. PM me when you join up!
2000uzj is my username.
Nick
Landcruiser Forum
