97 Land Cruiser brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 01-10-2005, 09:42 PM   #1 (permalink)
View hpyman123's Photo Gallery
Have 97 Land Cruiser. Replaced the pads front and rear and front rotors. What is the proper bleeding procedure. Pedal is firm with engine off but with it running pedal pumps up but gradually goes all the way down. Have bled manually at each wheel and have clean fluid at each one but must have some air trapped somewhere.
hpyman123 is offline   Reply With Quote
Old 08-09-2009, 07:35 PM   #2 (permalink)
View nicnic99's Photo Gallery
Spongy Brakes
CHECK THE LSPV (LOAD SENSING PROPORTIONING VALVE) JUST IN FRONT OF THE DRIVERS SIDE REAR WHEEL. MANY ENTHUSIASTS MISS OUT ON BLEEDING DONT KNOW THAT IT NEEDS TO BE BLED AS WELL AND IS USUALLY THE CAUSE OF AIR IN THE LINE AND SUBSEQUNTLY CAUSES A SOFT OR "MUSHY" PEDAL. A LOT OF PENETRANT AND PATIENCE WILL EVENTUALLY GET THE BLEEDER SCREW LOOSE. GOOD LUCK AND HTH
nicnic99 is offline   Reply With Quote
Old 08-10-2009, 10:28 AM   #3 (permalink)
View Makelo's Photo Gallery
If that doesn't work, I suggest to look int a new brake master cylindder
Makelo is offline   Reply With Quote
