OBD II P1121 Code '99 Land Cruiser - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Land Cruiser Forum
Land Cruiser Forum Dedicated Land Cruiser discussion forum.
Old 03-11-2005, 03:18 PM   #1 (permalink)
View bigdz's Photo Gallery
A few suggestions please. After I tow with this truck, I will have problems during restarting. As it has electronic throttle control, the car will either run and the throttle does not respond to foot movement or it will fire and immediately shut down. I get the P1121 code which is "Throttle Position (TP) Sensor Inconsistent With MAF Sensor High Voltage". I suspect that it is the TPS or the entire throttle controller. Does anyone have some diagnostics I can use to test specific components and narrow down the problem? I hate to just change parts needlessly. Could it be a dirty or bad MAF??
This only happens after I tow for ~300 miles and the trailer is ~5000 lbs. so the throttle is run significantly higher when it exhibits te problem.
bigdz is offline   Reply With Quote
Old 03-11-2005, 07:37 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
IT Sounds like the processor learned how to run with a heavy load and when you removed it, the throttle angle didnt match up with the air rate and it got confused and shut down, try this next time, leave it running, unhook the trailer and then drive the truck a couple miles to get it to relearn before you shut it off
