Trouble engaging 4wd - Toyota Nation Forum : Toyota Car and Truck Forums
General FJ Cruiser Discussion Discussion forum for the all-new 2007 FJ Cruiser!
post #1 of 8 Old 01-15-2011, 02:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
My four wheel drive will not engage. I have a 2007 fj with 56000 miles on it. It worked fine a month or so ago and in our first snow it will not go in. I can go to 4low and it will gear down but the front drive train does not kick in. any suggestions?
rtucker is offline
post #2 of 8 Old 01-15-2011, 05:47 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 3581 Post(s)
Hello, and to Toyota Nation! Let me move your thread over to the FJ forum so the other members there can help you out with your 4WD issue. You might also use that forum's search feature and see if any past threads have discussed how to engage/disengage the 4WD system.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline
post #3 of 8 Old 01-16-2011, 07:52 AM
Quoted: 32 Post(s)
Welcome. Someone here can help. I am not familiar with the FJ's. You have a stock suspension?
2003 Matrix Xrs, 2008 Corolla CE 5 spd, 2006 CE auto, '82 supra RIP
1990 Talon AWD w/35r, 1991.5 Dodge W250 CTD,
Cheap Fast or Good, Pick any two.
highpsi4 is offline
post #4 of 8 Old 01-16-2011, 09:42 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yes. Everything on the vehicle is stock.
rtucker is offline
post #5 of 8 Old 01-18-2011, 03:40 PM
Quoted: 0 Post(s)
Tranmission in neutral?? Slow speeds?? If YES try backing up and see if
that helps.
alpha17c is offline
post #6 of 8 Old 01-18-2011, 05:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yes, I have tried all that. tried going between 4h and 4l, backwards, forwards, wheels turned. I am thinking electrical, not sure where to start looking as far as that goes. thanks
rtucker is offline
post #7 of 8 Old 01-22-2012, 05:44 PM
MDT Toyota Tech
Quoted: 0 Post(s)
the most common problems are the front diff actuator and the transfer case position switch, the switch is on the pass. side of the transmission. disconnect the connector and put a paper clip in the 2 wire connector and see if engages. Does the light on the dash come on or flash?
BadChicken is offline
The Following User Says Thank You to BadChicken For This Useful Post:
alabamatacomaguy (03-21-2014)
post #8 of 8 Old 03-16-2014, 02:34 PM
Quoted: 0 Post(s)
I have the problem of my atrac or locker not engaging in 4l. I was wondering if you could post any more information about how to check the sensor. Or possibly a link to a thread about it. I get on the fj forum a lot but it will not work on my mobile device currently. It says the fj forum is not up to date or something.
But anyway I am trying to get my locker to engage and atrac to even just show a dash light.
Sent from AutoGuide.com App
alabamatacomaguy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > FJ Cruiser Forum > General FJ Cruiser Discussion
User Tag List
Linear Mode Linear Mode
Back
