sosche wire harness (orange wire) HELP!
(Click here to view the original thread with full colors/images)
Pages: 1
Posted by: sidetrippin
well... I connected all the wires but the orange and pink one are left. the pink one is from the head unit w/ a dvd player, its for the parking break... where can I tap it in? do I need to find a pink wire also? as for the sosche... there's this orange wire that I dont know where it goes... can somebody help me on this? Thanks.
Posted by: touringcamry
The orange wire is for illumination.
So... it doesnt go anywhere?
It depends on your HU. It just tells the HU to dim the lights when you turn the lights on.
Look for an illumination wire on your HU. If there isn't one, just cover it with some heatshrink.
oh ok...
Thanks... that clarifies it
what about the pink wire that goes on the parking brake? where can I connect that or where can I find to tap it?
I have the jensen phase linear in dash dvd player.
No idea about the pink wire. Is it supposed to be grounded or get +12V or something else?
My guess is that it just tells the HU when the parking brake is (dis)engaged. It is unlawful to have a video playing visible to the driver when the vehicle is in motion.
Posted by: MrSo0h0o
didnt the wire harness come with instructions telling you what each color wire represents?
Posted by: anoiel
the parking brake one is suppose to be hooked up to the hand brake so if you want to watch a movie the brake has to be on. The brake grounds the wire.
No it doesnt... I got it from ebay, I just match up the color of wire to the HU.
Posted by: Stealth
The pink wire will have to be hooked up to the parking brake or to a switched ground. The Phase Linear unit (if it's the same one that Circuit City sells) requires that you do a e-brake sequence in order to watch video.
Posted by: driving90
i just installed a kenwood audio head unit (no dvd or video) into my 08 corolla the other day. for my unit at least, it didn't need the orange wire so I just electrical taped it up. keep it there just in case you switch HUs again in the future, saves you the hassle of buying another harness if the next HU requires it.
Posted by: LoudCamry
hook the pink wire to the wire that the instructions tell where it should go,
On most alpine headunit the pink wire is for illumination, and on my kewood in dash the the pink wire is for nothing and i ground a light green wire which is suppose to be wire to the parking brake, i did that so i can watch dvd while driving, but ima remove it since i got a warning from a traffic stop which he didnt give me a tickert because he can't find the code for the ticket, I got a break.
Toyota Nation
vBulletin Copyright ©2000 - 2003, Jelsoft Enterprises Limited.
Page generated in 0.04579 seconds with 10 queries
