» Sponsors
» Sponsors
Go Back   Toyota Forums :: Toyota Nation > Toyota USENET Discussion Groups > alt.autos.toyota > alt.autos.toyota.camry
Register Home Forum Active Topics eBay Marketplace Photo Gallery Blogs Mark Forums Read
alt.autos.toyota.camry Toyota Camry discussion newsgroup.
Please Visit our Site Sponsors
Thread Tools Display Modes
Old 01-04-2006, 01:06 PM   #1
Butzmark
Guest
Posts: n/a
View Butzmark's Photo Gallery
Anybody know if stereo installation on a '92 Camry involves taking the whole dash out?
I had to do that in an '89 Celica and don't want to do it again.
Crutchfield used to show it on line but now you have to pay for the
info.
Old 01-08-2006, 08:06 AM   #2
3vn5l9b02@sneakemail.com
Guest
Posts: n/a
View 3vn5l9b02@sneakemail.com's Photo Gallery
Re: Anybody know if stereo installation on a '92 Camry involves taking the whole dash out?
If yours is like my '90 Camry, then no, you don't have to remove the
dash. In mine, there's a plastic frame surrounding the stereo, heater
controls, and ashtray. There are two screws at the top of the frame.
You remove the two screws and pull. Way back in '90, I had the
instructions from Crutchfield and thought I was doing something wrong
and would break that frame, because it seemed to be bending. I called
Crutchfield and they said I was doing it right. So I kept pulling and
the frame came out. After that, you can get at everything.
BK
Old 01-09-2006, 09:28 PM   #3
GrantTPC
Trader Rating: (1)
View GrantTPC's Photo Gallery
Use a screwdriver and pry under the two bottom rounded corners of the frame surrounding the Head unit and storage cubby.. It should just pop out.. Then lift the corners of the frame up and out and it will just come off.. Don't pry the top, or middle...the frame actually hooks under the dash fascia at the top edge and acts like a hinge.
Using a longish (at least 6") Phillips screwdrvier ("+" head) remove the 4 screws at each corner of the mounting frame. The right side screws are easy to see. The left side screws are a bit deeper. The entire metal frame with the radio and cubby pocket should simply pull out in one piece.
Un-clip the two connectors at the back ( the bigger connector is for the speakers, the smaller one is power and other control signals) and pull out the antenna plug and the radio assembly should now be free.
Using the same phillips screwdriver undo the 4 screws on the side of the radio (two per side) you then need to flex the frame a bitbecasue there are locatiog tabs, but the radio will eventually slide right out..
Slide your new head unit in and using the same screws you just removed put everyting back together in reverse order...
15 mintue job - tops (not including hooking up the wireing harness so the new radio gets power and a signal to the speakers
Hope this helps...
Chairperson, Toronto Prelude Club
1995 Honda Prelude SR, 1987 Toyota Supra (sold), 1988 Toyota Supra Turbo (sold), 1992 Toyota Camry, 2003 Honda CR-V
I still have too many cars..
GrantTPC is offline   Reply With Quote
Old 01-11-2006, 02:52 PM   #4
Butzmark
Guest
Posts: n/a
On Wed, 04 Jan 2006 13:06:35 -0500, Butzmark <me@my.net> wrote:
[color=blue]
>info.[/color]
Thanks allot for the replies.
vB code is Off
Smilies are Off
[IMG] code is Off
Forum Jump
Similar Threads
1999 Camry Stereo Installation LTJ Gen 3 & 4 3 10-04-2009 04:17 PM
Buddy's Camry '92 rear light issue Loka_K Gen 3 & 4 2 03-15-2005 01:26 PM
Took out old stereo and found an amp on Gen3 camry!! fernicus Gen 3 & 4 9 03-14-2005 02:30 PM
new stereo for the camry alex Audio, Video, and Security - Tech 3 03-17-2004 05:03 PM
Cold air intake on 92 camry luna123199 General Discussion 1 03-13-2004 01:12 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
