I just got done with my motor mounts this weekend and it was much easier than I thought. I had much more trouble getting off the rear adjustable arm because it was rusted on like you wouldn't believe.
Anyways..
Tools needed:
- Jack
- Small block of wood around 5 inches long
- PB blaster or penetrating oil or both
- 2 Jackstands
- offset 17 mm Wrench (regular one with a little bend so its not straight)
- Ratchet with 14mm regular and 14 mm deep sockets.
- Extensions for ratchet
- 17 mm socket (I believe but not sure)
- Big old breaker bar (mine was the 1/2" 3 foot or so one from autozone with the smooth handle and black end piece)
- Flashlight for looking around underneath the car
Instructions
1) Use 14mm to remove dogbone motor mount
2) jack up car and use jackstands enough to slide under
Rear mounts- slide under car
3) Reach up to the side of the downpipe and feel for the top bolt of the mount 17mm.
4) Put the wrench on so it faces downward. Put it on the side closer to the bracket thing with the foam cover.
5) Use your breaker bar and lever it against the front axle to the wrench. If you can get it lose just by pulling the wrench, good for you.
6) Loosen up the 17 mm nut.
7) Put the jack under the oilpan using the piece of wood between the oil pan and jack.
8) jack up the engine little by little and you'll see the top loosen up.
9) Remove the 3 14mm nuts with your 14mm deep socket
10) Jack up the engine more and more until you can get it out.
11) Shimmy the mount around the axle. You need to twist it different ways to get it out.
12) Install is pretty much the reverse
Front mount
1) lower engine and car back to its tires
2) Remove the top bolt (I think its a 17mm). Mine was stuck like you wouldn't believe. I used 4 extensions and the 3 foot breaker bar to get it loose. You don't want to whack the radiator with the wrench.
3) Remove the 2 side 14mm bolts from the top (I used extensions on the ratchets for this one too)
4) Remove the center 14mm bolt from underneath the car. Do not try to unscrew the 15mm nut on the top. Its welded to the motor mount.
5) Jack up the motor with the wood block till you can get it loose.
6) Shimmy it out around the side near the cruise control box.
7) Put the new one in and lower the jack slightly to line everything up.
Its not as difficult as many think. Especially the rear one. If you have the right tools you can bang it out in an hour. I'd PB Blast everything and come back in a few hours to try and loosen them.
Anyways..
Tools needed:
- Jack
- 2 Jackstands
Instructions
Front mount
