disclaimer ToyotaNation may or may not endorse various DIY projects such as this one, but all DIY projects are purely "at your own risk". If you are at all uncomfortable or inexperienced working on vehicles (especially electronics and mechanical), please reconsider doing the job yourself. It is very possible on any DIY to void your factory warranty, disable a safety feature, create a hazardous condition, or harm or even kill yourself or others. Examples would be the vehicle failing on you, getting an electric shock, or disabling an airbag to name a few.
so i decided to change my serpentine/accesory belt. i thought i'd share a little info while i was at it. my car is a california 2003 toyota camry LE 2az-fe. instructions apply to most 2az-fe fwd cars, including gen5/5.5 camry, gen 6 camry, and scion tC. i'm not sure about the 2az-fe highlander and rav4.
items needed
go to page 5 of the camry manual for the 5th gen and print out that page, or you can just save this portion to your computer and print it out:
^this page is necessary since it contains the pattern in which the belt should follow.
step 2 - taking out the old serpentine belt
first off, take a good look at the belt and memorize the belt routing and how all the smooth pulleys are in contact with the smooth side of the belt, and all the ribbed pulleys are in contact with the ribbed side of the belt. there are two ways to take off the belt; you can either loosen the tensioner and simply slip off the belt off the alternator pulley (the most accesible pulley imo), or you can loosen the tensioner and just cut the belt, and take the risk of the belt slapping you in the face pretty hard due cuz you wrongfully thought you gave all the slack it could . use the 19mm socket wrench on the indicated bolt in the diagram and pull it clockwise towards the front of the car. this requires a bit of effort- it may seem like it's stuck, but the hydraulic tensioner is really just that hard to budge *this is where the long wrench is desired*. you'll be able to see the belt give slack when you give it enough leverege- that's when you simply yank off the belt off the alternator pulley or whatever pulley you want. pretty straightforward.
with the belt off, this is a good time to check that the alternator, water pump, and a/c compressor pulley are able to rotate freely (don't rotate too much- just check). they also shouldn't be loose or be able to wobble.
step 4 - installing the new belt
with the old belt off, you pretty much reverse step 2, starting with putting the belt around all the pulleys (according to diagram) but the alternator pulley or tensioner pulley. make sure the belt is centered on all the pulleys (except the pulley yet to be wrapped around of course), especially the sections where it's rib-to-rib. place the socket wrench back on that 19mm bolt and pull clockwise towards the front of the car once again to release the tension. don't use anything to pry the belt on any pulley, because you may bend one of the pulleys or whatnot. with enough slack, you can put the belt back on.
step 5 - final check
check that the belt is on correctly. store all tools. consume beverage of choice. recycle.
good luck,
justanotherasian
items needed
- safety goggles (lol).
- 2az-fe serpentine belt (i chose goodyear gatorback #4070763 which is around $29.99).
- racheting socket wrench (the longer, the more leverage, the better).
- breaker bar (optional).
- 19mm socket (for your wrench).
- mechanic/working gloves (optional for extra grip).
- beverage of your own choice (keep out of engine bay of course ).
- update
- update
touringcamry said:
as for removing the front passenger wheel, and wheel well liner, i don't think that's necessary due to the ample amount of space between the wheel well and belt/pulley system. removal of the engine mount and engine cover is definitely not necessary because it is not hindering access to the whole belt/pulley system.
good luck,
justanotherasian
